    Bug (ish) on 1.24 "G30 P0 X0 Y0 Z-99999" before home locks Duet
    Firmware developers
    1
    1
    91
    • DocTrucker
      DocTrucker last edited by DocTrucker
      Hi.
      It appears that running:
      Before a home causes the DWC 2.0.0-rc7 to disconnect and the Duet to become unresponsive.
      Ok you shouldn't do that, but not sure how the Duet's temperature control loops would behave in that state had they been enabled, or indeed an external switched wired to trigger the e-stop and reset.
      Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
