WiFi disconnecting only when printing
  • Hello all,
    I Have a Duet 2 1.03 with FW 2.03, DuetWiFIServer 1.23 and DuetWebControl 1.22.6
    The issue I am describing was not present in Duet FW 2.02 with DuetWiFIServer 1.23 and DuetWebControl 1.22.3
    What happens is this:
    • If I am not printing, the Duet stays connected to the WiFi indefinitely; no issues.
    • The Duet stays connected while preheating, mesh bed level and probably for the first couple of lines of printing
    • I havent determined the exact location in the Gcode for the disconnect; but, after about 5 minutes into the print, the Duet disconnects from the Wifi. The blue LED on the ESP turns off
    This happens on ALL prints, regardless of which slicer I use. I have tried S3D, Prusa Slicer 2.0
    I dont know whats happening. Any help would be highly appreciated.
    Thanks,
    Madhu.
    When it has disconnected, please send M122 from USB and post the report here. Or you may be able to pause the print, reconnect DWC, then send M122 from DWC. Note, only the figures from the first M122 after the problem happens are relevant.
    How certain are you that it didn't happen with firmware 2.02? Did you run exactly the same print under 2.02?
  • Hi @dc42 ,
    Here is the M122 output:
    === Diagnostics ===<LF>Used output buffers: 1 of 24 (11 max)<LF>=== RTOS ===<LF>Static ram: 25680<LF>Dynamic ram: 93696 of which 0 recycled<LF>Exception stack ram used: 452<LF>Never used ram: 11244<LF>Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,1668) IDLE(ready,160)<LF>Owned mutexes: WiFi(NETWORK)<LF>=== Platform ===<LF>Last reset 00:07:02 ago, cause: software<LF>Last software reset at 2019-08-11 00:00, reason: User, spinning module GCodes, available RAM 11372 bytes (slot 3)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d<LF>Error status: 0<LF>Free file entries: 9<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 25.0, current 25.5, max 25.7<LF>Supply voltage: min 23.2, current 23.4, max 24.2, under voltage events: 0, over voltage ev<Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
    I am sorry about the formatting; but, I just copied and pasted the output on YAT directly.
    Please let me know in case you need more info.
    Thanks,
    Madhu.
    Please change the YAT line ending settings to just <LF> (step 3 at https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7?lang=en) and run the M122 again.
  • @dc42 ,
    Here is the fresh M122 outout:
    RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.03 dated 2019-06-13b2
    Executing config.g...HTTP is enabled on port 80
    FTP is enabled on port 21
    TELNET is enabled on port 23
    Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
    Done!
    RepRapFirmw
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
    Used output buffers: 1 of 24 (8 max)
    Static ram: 25680
    Exception stack ram used: 440
    Never used ram: 11256
    Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
    Last reset 00:06:39 ago, cause: software
    Last software reset at 2019-08-11 14:36, reason: User, spinning module GCodes, available RAM 11376 bytes (slot 1)
    Error status: 0
    Free file entries: 7
    SD card longest block write time: 7.7ms, max retries 0
    MCU temperature: min 26.9, current 28.5, max 28.8
    Supply voltage: min 23.2, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: ok, SG min/max 0/100
    Driver 1: ok, SG min/max 0/48
    Driver 2: ok, SG min/max 0/1023
    Driver 4: ok, SG min/max 0/3
    Date/time: 2019-08-11 14:43:31
    Cache data hit count 1587842547
    Slowest loop: 105.25ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 166, MinFreeDm: 163, MaxWait: 297857ms
    === DDARing ===
    Scheduled moves: 8, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Heater 0 is on, I-accum = 0.6
    Heater 1 is on, I-accum = 0.5
    Segments left: 0
    Stack records: 2 allocated, 2 in use
    Movement lock held by file
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 43 8 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 200.97ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    • WiFi -
      Network state is running
      Failed messages: pending 0, notready 0, noresp 75
      Failed to get WiFi status
      ok
    Thanks,
    Madhu.
  • okay; heres a change in the situation:
    • When I lost the connection to DWC, I sent M552 S1 to check if the board would connect to WiFi. It just replied OK and did not do anything
    • I then sent M552 S0; it gave me an error that the wireless mode could not be changed
    • Sending M552 S1 again switched the WiFi on and the board was able to connect to the network.
    And, I have carefully noticed; the DWC connection drops the moment the pre-heat is done and the printer starts to move.
    ~Madhu.
  • @dc42 ,
    any thing else I need to do?
    I can confirm that this issue exists with DuetWiFIServer 1.22 and Duet FW 2.02 as well.
    THanks,
    Madhu.
