Stuck in spin loop
  • Since installing the FW 2.04RC1 I have been experiencing freezing on occasions when starting the GUI interface. The card is a genuine Duet 2 Maestro.
    The browser I use is google chrome. It only happens when accessing the GUI on some occasions and every time up till now is when I'm printing.
    Ive been running a few diffrent versions of the FW but never had any freezing before. It's happened about 5 or 6 times over a few weeks, my printhead just stops, I lose contact through the browser and I have to restart the printer. I take it this is a bug??
    The Web interface version 1.22.6.
    Thoughts or possible fixes to try would be appreciated.
    Here is the M122 diag which I ran immediately after a reboot ....
    RepRapFirmware for Duet 2 Maestro version 2.04RC1 running on Duet Maestro 1.0
    Used output buffers: 3 of 24 (7 max)
    Static ram: 19664
    Dynamic ram: 94352 of which 0 recycled
    Exception stack ram used: 332
    Never used ram: 16724
    Tasks: NETWORK(ready,660) HEAT(blocked,1276) MAIN(running,3908) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:03:32 ago, cause: power up
    Last software reset at 2019-08-10 19:43, reason: Stuck in spin loop, spinning module GCodes, available RAM 16396 bytes
    (slot 3)
    Software reset code 0x4043 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f80f BFAR 0xe000ed38 SP 0x20000da4 Task 0x5754454e
    Stack: 0044412b 00447c02 61000000 00000000 00000004 00447ded 20003fd4 00000001 20000758 10000000 00000004 2000783c
    00008ea0 00000004 0044441d 00000004 00000000 00000001 0041a69f 20000e24 01e05fff 00000000 00403101
    Error status: 0
    Free file entries: 9
    SD card 0 detected, interface speed: 15.0MBytes/sec
    SD card longest block write time: 13.9ms, max retries 1
    MCU temperature: min 33.1, current 35.1, max 35.8
    Supply voltage: min 0.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, read errors 0, write errors 0, ifcount 8, reads 8472, timeouts 0
    Driver 1: standstill, read errors 0, write errors 0, ifcount 8, reads 8472, timeouts 0
    Driver 2: ok, read errors 0, write errors 0, ifcount 8, reads 8472, timeouts 0
    Driver 3: standstill, read errors 0, write errors 0, ifcount 6, reads 8469, timeouts 5
    Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 8474, timeouts 0
    Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 8480
    Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 8479
    Date/time: 2019-08-10 19:48:22
    Slowest loop: 137.87ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 168, MinFreeDm: 166, MaxWait: 120262ms
    === DDARing ===
    Scheduled moves: 38, completed moves: 37, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Bed heaters = 0, chamberHeaters = -1 -1
    Heater 0 is on, I-accum = 0.3
    Heater 1 is on, I-accum = 0.6
    Segments left: 0
    Stack records: 3 allocated, 0 in use
    Movement lock held by file
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 33
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    lcd is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 114.22ms; fastest: 0.02ms
    HTTP sessions: 1 of 8
    Interface state 5, link 100Mbps full duplex
    What firmware were you running before you upgraded to 2.04RC1?
  • I was Running 2.02 and then 2.03.
    The problem is very intermittent, if there is anything more I can do for you diagnostically to enable a better trace of the problem then let me know and I will try to reproduce it and maybe give you more information what I discover?
