    PanelDue 1.16beta2 firmware now available
    Firmware installation
    1641
      It's at https://github.com/dc42/PanelDueFirmware/tree/master/Release/Edge. As usual, follow the link to the binary you want and then press Download. The baby stepping buttons only work with 1.18beta3 and later Duet firmware.
      • PDBeal
        PDBeal last edited by
        Is that the only change in the firmware from the previous release? Just trying to decide if its something I need to update or just for "special" features I've been living without.
          The only change most users are likely to see is that when you pop up the keyboard on the Messages page and then switch to another page and back, the keyboard is now re-drawn in the correct place.
          • ChrisP
            ChrisP last edited by
            I haven't tried this latest version just yet (I use a 7" screen with a CPLD driver, so I need to roll my own version), but I noticed in the previous version that when all the extra extruder information is removed from the control page it doesn't also remove the heat bed. The systems I usually run don't have heated bed, so I disable that option in config.g to prevent it being shown on the web interface, but the icon still appears on the PanelDue.
            This isn't a huge problem, however, while pressing the first heater icon activated the heater, the setpoint and current temperature values are displayed under the heatbed icon.. The values under the first nozzle icon remain at 0. Also, pressing the icon again doesn't seem to de-activate the nozzle to cool it down. I've only recently got a PanelDue, so maybe this isn't a thing, but I'm a little surprised if it isn't. Or am I missing a more obvious way to deactivate a nozzle to cool it - at the moment, I just press the E-stop?
            • Pumlux
              Pumlux last edited by
              Looks like the link in the first post ist broken.
              Using a own build of a Mendel Max , Duet Wifi, Bed 8 mm Aluminium PEI 500 x 280 x 400 230 V 850 W, original E3D Chimera hotend with bowden length 700 mm, since short time with a BL-Touch, Steppers : mostly Nema 17 and one Nema 23 for Y-axis
                The 1.16 release is now at https://github.com/dc42/PanelDueFirmware/tree/master/Release/Stable.
                • Adamfilip
                  Adamfilip last edited by
                  babystepping going to be an option directly on PanelDue?
                  • hamel
                    hamel last edited by
                    @Adamfilip:
                    It is on the 1.16 I have been using for a while now.
                    • Adamfilip
                      huh, I have updated to 1.16, im not seeing it..
                        You will only see the babystepping button when a print from SD card is in progress. It's on the Print page next to the Pause button.
                        • Adamfilip
                          Yep, found it.. never mind đŸ™‚
                          Thanks
                          • gate546
                            gate546 last edited by
                            @dc42:
                            Hello
                            Seem that the folder was missed….
                            Dommy
                              That's because it has been released since I posted that link, so it's now in Stable instead of Edge.
