    1.18 RC1 Bed levelling
    Firmware installation
    1465
    • pcsentinel
      pcsentinel last edited by
      Hi DC42 can you expand on the line in the release notes that says:
      M557 P parameter to set probing points is no longer supported. Use a bed.g file instead
        It used to be possible to do 3, 4 or 5 point bed probing without using a bed.g file, by defining the probe points in M557 commands. This was replaced by the use of a bed.g file 2 or 3 years ago; but if there was no bed.g file then the old way was still supported.
        • pcsentinel
          Ok thanks, if I may ask a further maybe stupid question, I have been using 4 point as per many previous posts, but have discovered that the bed coating I use severely affects the IR Probe trigger height, is there a way to save probing results from 4 point as there is with Mesh levelling?
          Also I think the Web interface may have an issue, if I click on the down arrow for auto bed compensation and select Mesh level nothing happens, if I gcode it it runs fine.
            The web interface issue is known and fixed in the release that chrishamm has under development.
            There isn't a way of saving the results of 4-point probing, but you can use 4-point mesh levelling instead.
            • pcsentinel
              Thanks again, I'll give it a try.
              • pcsentinel
                Hi DC42, struggling with four point mesh, I cant seem to figure out what to put in the M557 command to get it to go to the corners of the bed. I have a 28X 28Y offset to the probe and a 200x200 bed
                If I try
                M557 X0:160 Y0:160 S159 it tries then comes back with not enough points error
                  If the probe offset is +28X and +28Y then the point 0,0 is not accessible to the probe unless the nozzle can move to -28X -28Y. So try probing from about 30 to 190 instead of 0 to 160.
                  • pcsentinel
                    Sorted, thanks for your help, settled on
                    M557 X40:190 Y20:170 S150
                    • Russ Gries
                      Russ Gries last edited by
                      Question,
                      I was trying to set the bed mesh manually, i changed the points in the CSV. then saved it, then i set a M375.
                      but from what i could tell nothing changed.
                      I'm i doing this correctly? or is there another step?
                      Thanks!
                      ~Russ
                      One Day At A Time…
                      My Main Research Page:
                      http://rwgresearch.com/open-projects/3d-printing-research/
                        @Russ:
                        Question,
                        Thanks!
                        ~Russ
                        That should work, but use the 1.18 release of at least 1.18RC2. There was a bug in earlier versions when loading large height maps files.
                        • Russ Gries
                          ok, Ii will give it a go when I have troubles again, Thanks!
                          ~Russ
                          One Day At A Time…
                          • pcsentinel
                            Hi DC42, just found an oddity, for a laugh I did mesh levelling with:
                            M557 X52:204 Y20:170 S12.5
                            I then printed 4 x 10mm square 1mm high at the edges of the plate, each of the squares had each layer in the Y direction slipped by about 0.2mm
                            Odd?
                              @pcsentinel:
                              Odd?
                              Is it reproducible? If so, feel free to remind me about this about a week from now, when I should have time to look into it.
