    M555 does not work in config.g
    Beta Firmware
    345
    • JuKuundefined
      JuKu
      This is not really a help request, but FYI. (Is there an issue list for RRF3 somewhere?). Anyway, I have "M555 P6" as the last line in my config.g; it does not work. When I send it from USB, it works as expected.
      FIRMWARE_NAME: RepRapFirmware for Duet 3 v0.6 FIRMWARE_VERSION: 3.0beta10 ELECTRONICS: Duet 3 version v0.6 FIRMWARE_DATE: 2019-09-12b1
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal
        Could it be a line end thing? Try putting a harmless command after the M555 in config.g??
        • JuKuundefined
          JuKu
          Not that.
          • fcwiltundefined
            fcwilt
            Did you try as the first line?
            • Stephen6309undefined
              Stephen6309 @JuKu
              @JuKu The text may be sent to the bit bucket like the error messages that you can't see unless you run config.g after bootup.
                dc42 administrators @Stephen6309
                In RRF3 the M555 setting is on a per-input basis. The beta build of RRF3 defaults to Marlin compatibility for the USB input channel. Do you need something different?
                JuKuundefined 1 Reply Last reply Reply Quote 0
                • JuKuundefined
                  JuKu @dc42
                  @dc42 Thank you for the explanation. As I said, this was not a help request, I brought it up in case there is a problem. For me, it is fine as it is, as I’m controlling the Duet from my own software. I need the nanoDLP compatibility, because in my application, I need to know when the machine has stopped. But since it is my software, there is no problem to send the command at startup.
                    Perhaps we should add a parameter to M555 to specify which channel it should be applied to, so that it can be used in config.g.
