DWC Java
I added a fan and set it up using the RRF config tool and installed it using DWC. Now, if I try to simulate or print I get this message. I have updated the firmware and DWC, tried previous working config files, and no matter what I do I get this message. Help! I'm not a software guy by any means.
JavaScript Error
A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
Version: 1.22.6
Message: Uncaught TypeError: Reduce of empty array with no initial value
URL: http://192.168.29.233/js/dwc.js
Line: 1413:46
Error object: {}
Which firmware version are you using on the Duet?
I just updated everything in hopes of fixing the problem
Firmware Version: 2.03 (2019-06-13b2)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6
Redid everything using the RRF config tool and it seems to be working now.
