SOLVED G60 Not Working Correctly in System Macros
  • In my pause.g file I have the following:
    G60 S1 ; save current position
    M83 ; relative extruder moves
    G1 E-10 F3600 ; retract 10mm of filament
    G91 ; relative positioning
    G1 Z5 F1800 ; lift Z by 5mm
    G90 ; absolute positioning
    G1 X128 Y220 F6000 ; go to X=128 Y=220 (rear center)
    This system macro, when executed from the web interface, functions as I would expect. The print pauses, a retraction is performed, and the print head moves up and to the back of the machine.
    This is the code in resume.g:
    G1 R1 X0 Y0 F6000 ; go to x/y position of the last print move
    G1 E10 F3600 ; advance filament to starting position
    G1 R0 Z0 F450 ; move to 0mm above part
    When the resume.g system macro is executed, the print head moves to (0,0) at F3000 (50 mm/s) before returning to the print and resuming. I'm unsure where this command is coming from. None of the commands in my macros specify a feedrate of 50mm/s.
    And when I execute these commands in user-defined macros without the M24/M25 commands, the behavior is as expected.
    I want to eliminate the move to (0,0), but I can't find where that command is originating from. Is there something that I'm missing? Is my understanding of the G60 command wrong?
    Thanks,
    Luke
  • @Lukrative
    Well a couple of things to check.
    When a print is paused the current position is saved in slot 1 so I don't think you need that G60 S1.
    And you have that G1 R0 Z0 F450 command - when is slot 0 set?
    And you mention M24/M25 - where are these being used?
    Thanks.
  • Thanks for your reply @fcwilt,
    The R0 that you see is left over from when I tried changing everything over to slot 0 from slot 1, just to see if slot 1 was reserved for something else (I came to find out that, as you have said, slot 1 is already reserved for pausing prints). When I posted this issue I forgot to change everything back. It doesn't work even when all the commands use only slot 1.
    As far as the M24/M25 commands are concerned, they are called automatically when you hit resume/pause. You can see this if you check the G-Code Console on the web interface after you pause and resume.
    I did just try eliminating the G60 S1 command, but it made no difference. 😞
    @Lukrative said in G60 Not Working Correctly in System Macros:
    Why are you using G60 S1 at all, given that the coordinates at the point of executing the pause are saved in restore point #1 automatically?
    Which firmware version are you using? Support for G60 was added quite recently AFAIR.
  • @dc42 said in G60 Not Working Correctly in System Macros:
    I added that after my first test run failed, just to make sure that it actually was storing the position.
    The web interface shows this: 2.02RC5(RTOS) (2018-11-28b1)
    Here is my updated pause file:
    G1 E-10 ; retract 10mm of filament
    G1 Z5 ; lift Z by 5mm
    G1 X128 Y220 ; go to X=128 Y=220 (rear center)
    I removed all gcodes from resume.g. With these changes, it now returns to the correct x/y coordinates without passing through the origin, and then it moves back down in the z. The behavior is the way I want it now, so I'm not worrying about it too much, but hopefully I was able to be helpful if this turns out to be a real issue.
    You are using an old, unsupported release candidate firmware version. Please upgrade to 2.03 or 2.04RC1 and test again.
  • For posterity's sake, updating the firmware fixed it 🙂
