    work coordinate system display regression
    Duet Web Control
    duet 3 dwc2
    1
    • jannauundefined
      jannau
      Hej,
      I'm using a Duet 3 v0.6 + Raspberry Pi 4 as controllor for a CNC in CNC mode. I'm using the unstable apt repository and a recent update broke the display of the tool position in a work coordinate system. The tool position is not changed after setting work coordinate offset and seems to just reports the position in machine coordinate system. The machine position (after clicking on "Tool Position" in the dashboard) is always reported as "n/a".
      This seems to be just a display issue. M114 reports expected work and machine positions and move commands are executed in the work coordinate systems. The regression started after following updates (extracted from /var/log/apt/history.log*).:
      duetwebcontrol:armhf (2.0.0-5, 2.0.0-7), duettools:armhf (1.0.4.1, 1.1.0.2), reprapfirmware:armhf (1.0.4.1-1, 1.1.0.2-1), duetwebserver:armhf (1.1.1.0, 1.1.2.1), duetcontrolserver:armhf (1.0.4.1, 1.1.0.2), duetruntime:armhf (1.0.4.1, 1.1.0.2), duetsoftwareframework:armhf (1.0.4.1, 1.1.0.2), duetsd:armhf (1.0.3, 1.0.4)
      Due to the multiple updated compoments I'm not quite sure it is a regression in duet web control. Is there a good guideline were to report bugs where it's not quite clear if they are in RepRapFirmware, DuetSoftwareFramework or Duet Web Control for Duet 3 + SBC setups?
      • jannauundefined
        jannau
        Fixed in duetwebcontrol 2.0.1
