Magnetic Filament Monitor Sensor Distance
@T3P3Tony I'm in the process or designing an extruder that integrates the MFM mount and would like to verify the recommended distance between the magnet and the sensor. According to measurements from the provided STLs, the distance between the magnet and sensor is 0.3mm. Is this correct?
@dc42 @T3P3Tony - David or Tony, can you help with this question? I've completed the extruder design and would like to verify the distance from the magnet to the sensor before having it MJF printed. I believe it is 0.3mm, can you confirm?
Thank you in advance.
Yes, that is about right.
Great, thank you.
