    No tool is selected ?
    Duet Web Control
    • Rudy2Aundefined
      Rudy2A
      I am confronted from time to time with this message: "NO TOOL IS SELECTED"
      and I do not know why, because everything prints normally without error?
      Who could tell me why I have this random message?
      Circuit: Duet WiFi 1.02 or later
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04RC4 (2019-10-19b1)
      Duet WiFi Server Version: 1.22
      • Vetiundefined
        Veti
        you have no tool selected.
        issue the T0 command to select it.
        you can put it in your config.g as well
        • Rudy2Aundefined
          Rudy2A
          I certainly did not speak well!
          I have my tool T0 is selected and everything works normally ... Except that from time to time, randomly, I have the message that appears ... But, despite this message, my printer works normally.
          • Vetiundefined
            Veti
            where have you got your T0 command?
            Rudy2Aundefined 1 Reply Last reply Reply Quote 0
            • Rudy2Aundefined
              Rudy2A @Veti
              @Veti
              It is set in my slicer (Simplify3d).
              • Vetiundefined
                Veti
                @Rudy2A said in No tool is selected ?:
                that explains why your it always prints fine.
                if you try to do something else (heat up etc.) before your first print you will get the message "NO TOOL IS SELECTED"
                just add T0 to your config as well.
                • Rudy2Aundefined
                  Rudy2A @Veti
                  @Veti
                  I understand, thanks for the explanation ... I will also include T0 in Config.
                  Thank you
