New Duet3 unofficial beta firmware
I've put new firmware binaries for Duet 3 main boards (both version 0.5 and 0.6) and expansion boards at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0. These are not official releases because I haven't tested the corresponding builds for Duet 2 boards.
Changes in this build:
- Fixed issue with Z probe types 8 and 9 reading 250 when triggered instead of 1000
- Added hardware averaging to thermistor/PT1000 readings on expansion boards
- Changed returned board type name for compatibility with ATE
- Added firmwareVersion field to M408 S3 response for ATE
- Fixed M308 S# reply when there were no other parameters
- Fixed issue with updating Duet 3 expansion boards from local SD card when USB was connected to a PC but no terminal program was running
