Information for DC42: V3 Beta12 crashed mid print.
  • Crash mid-print for no obvious reason. Just FYI. Printing a job I'd printed before.
    CoreXY. Multi-Tool. Using tool0 at the time, probably the 10th swap.
    Board: Duet 3 MB6HC (MB6HC)
    DSF Version: 1.1.0.5
    Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12 (2019-11-02b1)
    M122 B0
    RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0beta12 running on Duet 3 MB6HC
    Board ID: 08DGM-9T66A-G63SJ-6J1DD-3SD6K-1V0MA
    Used output buffers: 1 of 32 (9 max)
    Static ram: 122240
    Dynamic ram: 173288 of which 0 recycled
    Exception stack ram used: 568
    Never used ram: 97120
    Tasks: NETWORK(ready,2044) HEAT(blocked,1212) CanReceiv(suspended,3420) CanSender(suspended,1400) CanClock(blocked,1428) TMC(blocked,80) MAIN(running,4212) IDLE(ready,200)
    Owned mutexes:
    Last reset 00:35:33 ago, cause: software
    Last software reset at 2019-11-02 19:07, reason: Unknown, spinning module Platform, available RAM 97160 bytes (slot 0)
    Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    MCU temperature: min 45.9, current 46.4, max 46.9
    Supply voltage: min 24.1, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
    12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
    Driver 0: standstill, reads 40765, writes 43 timeouts 0, SG min/max 0/1023
    Driver 1: standstill, reads 40766, writes 43 timeouts 0, SG min/max 0/1023
    Driver 2: standstill, reads 40771, writes 39 timeouts 0, SG min/max 0/92
    Driver 3: standstill, reads 40772, writes 39 timeouts 0, SG min/max 0/1023
    Driver 4: standstill, reads 40773, writes 39 timeouts 0, SG min/max 0/1023
    Driver 5: standstill, reads 40774, writes 39 timeouts 0, SG min/max 0/1023
    Date/time: 2019-11-02 19:42:57
    Slowest loop: 86.93ms; fastest: 0.25ms
    Hiccups: 5, FreeDm: 375, MinFreeDm: 335, MaxWait: 242505ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 21, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Stack records: 3 allocated, 0 in use
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is assembling a command in state(s) 0
    daemon* is ready with "M122 B0" in state(s) 0
    queue is idle in state(s) 0
    lcd is idle in state(s) 0
    spi is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 1.52ms; fastest: 0.01ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
    HTTP sessions: 0 of 8
    - Ethernet -
    State: 0
    === CAN ===
    Messages sent 20703, longest wait 78ms for type 6024
    === Linux interface ===
    State: 0, failed transfers: 4
    Last transfer: 26ms ago
    RX/TX seq numbers: 3611/249
    SPI underruns 9, overruns 8
    Number of disconnects: 1
    Buffer RX/TX: 0/0-0
    === Duet Control Server ===
    Duet Control Server v1.1.0.5
    Code buffer space: 4096
    Configured SPI speed: 2000000 Hz
    Full transfers per second: 30.93
    Thanks. Did you run that M122 35 minutes after it started printing, or 35 minutes after it stopped?
  • 35 min after it stopped.
    Thanks. I can tell that the reset was commanded by DSF, but not why. Is there anything in the DSF log?
  • How would I access the DSF log?
  • @Danal said in Information for DC42: V3 Beta12 crashed mid print.:
    On the Pi... journalctl -u duetcontrolserver
    You can leave the log running with... journalctl -fu duetcontrolserver
    @Danal Please run 'sudo journalctl -u duetcontrolserver', press G and type '?has been reset' followed by RETURN. That way you can jump to the log where the last RRF reset was reported. If it isn't the part where the corresponding reset occurred, press ? and RETURN to jump to a previous occurence. It would probably help to see what was being executed when the reset occurred.
  • Fantastic, thank you. Will find the correct spot and report it here, later this evening (US time).
  • The oldest log I can find with journalctl -u duetcontrolserver is after that crash. If it occurs again, I'll immediately capture that log.
