Paused by Filament Monitor or button
  • Is there a method to determine if the monitor caused the pause or the pause button was pressed? The firm ware knows when an external trigger causes the pause, it puts up a message. How can one determine how the pause was executed?
  • Since no one seems to have replied - yes if you enable the eventloging function in the firmware, it will state what caused the pause to occur. It will also show as a pop up notification on the web console. In the console itself it will just say it was paused though.
