    Unsolved Cura slicer: Layer count when print sequence is "Once at a Time"
    Duet Web Control
    cura layer time once print sequence
    • AfanasevSA
      AfanasevSA last edited by AfanasevSA
      Dear community and administration!
      I'm using only Cura slicer and there is a bug, when selected "Special Modes" / "Print Sequence" = "Once at a Time".
      Two screenshots: DWC and Cura.
      You can see 5 details, in first will be printed bottom row from right to left (the same details with max height eq. 5 mm, 25 layers), then (last) upper frame (height is 3 mm, 15 layers).
      DWC reports me, that there is only 15 layers and 3mm height, as for last detail. So, while printing, I've got "Layer: 25 of 15" (because first detail has 25 layers) and last value of "Current Layer Time" will count up to the end of file (real last layer).
      I've tried to edit g-code file (edit first ";LAYER_COUNT:" and delete others, renumber all layers at ";LAYER:"), but no - looks like DWC determine number of layers in other way - change of Z value.
      I think, that DWC g-code parser should enumerate not only positive Z change, but all Z changes. What do you think?
      PS I've searched for the same problem here, but looks like nobody use "Once at a Time".
      • AfanasevSA
        Hi everyone!
        No ideas about this? Maybe mr. @dc42 could give any comments?
        Mostly, I'm interested in how DWC determines layer quantity.
          dc42 administrators @AfanasevSA last edited by dc42
          @AfanasevSA said in Cura slicer: Layer count when print sequence is "Once at a Time":
          That's right the firmware looks at Z moves near the end of the file to determine the object height, and calculates the layer height form that. But in future I plan to make use of layer comments, when they are present.
          That may cause problems when users put tool change scripts or tool offsets in the slicer, because then the slicer will generate negative Z movements. So I think the current plan to use the layer height comments is better.
          AfanasevSA 1 Reply Last reply Reply Quote 0
          • AfanasevSA
            AfanasevSA @dc42 last edited by
            @dc42 thanks for your answer.
            Are layer comments the same for every slicer?
            Could you answer two more questions, please:
            1. How DWC determines layer change?
            2. If I'll place any G-command (one or block of commands) with summary Z, DWC will take it, divide per layer height, then show me correct info? You wrote, that it looks for Z moves , so, it looks like "last Z" minus "pre-last Z" = "layer height" for DWC, then "last Z" / "layer height" = "layer quantity"?
