M28 not working in RRF3
I am trying to build a workaround for calling
M32
from within gcode files, so I thought I could override a macro file throughM28
to start the next gcode file. (Related topic here)Whatever I am trying, I can't get M28 to even create a file, neither in the gcode directory nor in the macro directory.
M28 "loggingfile.gcode"
Error: Can't open file loggingfile.gcode for writingM28 0:/GCODES/DIR_TESTING/LOGGINGFILE.G
Error: Operation failed (Reason: Command SimpleCode has reported an error:
[ArgumentException] Code is too long)M28 "0:/GCODES/DIR_TESTING/LOGGINGFILE.G"
Error: Can't open file 0:/GCODES/DIR_TESTING/LOGGINGFILE.G for writing.M28 "0:/macros/m_one"
Error: Can't open file 0:/macros/m_one for writing.M28 "0:/macros/mone.g"
Error: Can't open file 0:/macros/mone.g for writing.Anyone knows if this is my mistake or a bug?
@too said in M28 not working in RRF3:
[ArgumentException] Code is too long)From that I presume you are running on Duet 3 using an attached RPi or other single board computer; in which case it is a DSF issue, not a RRF issue. We'll look into it.
@dc42 Yes, I am running the Duet3 with a Raspberry Pi 4 attached.
In case that influences anything - I am accessing the files on the virtual SD through a remote computer, so I changed the permissions for the folders to rwx-rwx-rwx
Hey @dc42, any updates on this? I also have issues with M28 on a similar setup.
@dc42 did you get any further on the DSF M28 issue?
I'm waiting for @chrishamm to look into it.
