    Duet 2 WiFi with RepRap on CR-20 Pro
    Firmware installation
    • amv101undefined
      amv101
      I just picked up a Creality CR-20 Pro and after some research I became interested in regards to upgrading the board and firmware to run the machine.
      Question, has anyone had any luck running the Duet 2 WiFi with the RepRap firmware on the CR-20 Pro? It seems to be almost the same as the Ender 3, but with a couple minor differences. I did some searching, but it seems the CR-20 isn't used by many people.
      Thanks in advance!
      • Vetiundefined
        Veti
        seems close to the ender 3.
        the lcd will not work and you will have to see for yourself if the board would fit inside the case.
          Here's a series of guides that take an Ender 3 Pro and upgrade it with a Duet Maestro.
          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
          It won't be exactly the same, but it should be a useful outline on how an upgrade would be done. It goes through commissioning and testing as well as basic tuning.
