    Filament usage / Completion estimates not working?
    Duet Web Control
    • MRobundefined
      MRob
      Hi - just got everything set up on my Maestro, all working well except the filament usage and % complete is broken for some reason. It has a number for total filament that will be used during the print (pulled from the gcode file), but it is not adding up the used filament properly. Here is a picture at the end of the print, showing a negative value for filament used!!maestrofila.jpg
      Although it shows 100% now, during the actual print it typically hovers at a very low number. When I was printing a calibration cube earlier, it was stuck on 0% (probably on -ve used, but didnt know to check then)
      Any ideas??
      Edit: Latest stable firmare
        What is the DWC version? What slicer? Can you supply the gcode file in question?
        • MRobundefined
          MRob
          Upgraded firmware to latest, so 2.05. Using Prusa slic3r. Gcode, same issue with many models but copied are the start and end portions of one I tried:
          ; generated by PrusaSlicer 2.1.0+win64 on 2019-12-01 at 18:13:35 UTC
          ; external perimeters extrusion width = 0.60mm
          ; perimeters extrusion width = 0.60mm
          ; infill extrusion width = 0.68mm
          ; solid infill extrusion width = 0.68mm
          ; top infill extrusion width = 0.68mm
          ; support material extrusion width = 0.52mm
          ; first layer extrusion width = 0.63mm
          M107
          M190 S85 ; set bed temperature and wait for it to be reached
          M104 S240 ; set temperature
          G28 ; home all axes
          G1 Z2 F8000 ; lift nozzle
          G1 X150 Y10
          M109 S240 ; set temperature and wait for it to be reached
          G21 ; set units to millimeters
          G90 ; use absolute coordinates
          M82 ; use absolute distances for extrusion
          G92 E0
          ; Filament-specific end gcode
          ;END gcode for filament
          M104 S0; Set Hot-end to 0C (off)
          ;M140 S0; Set bed to 0C (off)
          G91
          G1 F1800 E-2
          G1 F5000 E-3 Z5
          G90
          G28 X0 ; home X axis
          M84 ; disable motors
          ; filament used [mm] = 3032.0
          ; filament used [cm3] = 7.3
          ; filament used [g] = 7.3
          ; filament cost = 0.1
          ; total filament used [g] = 7.3
          ; total filament cost = 0.1
          ; estimated printing time (normal mode) = 2h 10m 7s
          ; avoid_crossing_perimeters = 0
          ; bed_custom_model =
          ; bed_custom_texture =
          ; bed_shape = 0x0,280x0,280x300,0x300
          ; bed_temperature = 85
          ; before_layer_gcode =
          ; between_objects_gcode =
          ; bottom_fill_pattern = rectilinear
          ; bottom_solid_layers = 4
          ; bridge_acceleration = 0
          ; bridge_angle = 0
          ; bridge_fan_speed = 100
          ; bridge_flow_ratio = 0.9
          ; bridge_speed = 10
          ; brim_width = 5
          ; clip_multipart_objects = 0
          ; complete_objects = 0
          ; cooling = 1
          ; cooling_tube_length = 5
          ; cooling_tube_retraction = 91.5
          ; default_acceleration = 0
          ; default_filament_profile = ""
          ; default_print_profile =
          ; deretract_speed = 0
          ; disable_fan_first_layers = 2
          ; dont_support_bridges = 1
          ; duplicate_distance = 6
          ; elefant_foot_compensation = 0
          ; end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n"
          ; end_gcode = M104 S0; Set Hot-end to 0C (off)\n;M140 S0; Set bed to 0C (off)\n\nG91\nG1 F1800 E-2\nG1 F5000 E-3 Z5\nG90\n\nG28 X0 ; home X axis\nM84 ; disable motors\n
          ; ensure_vertical_shell_thickness = 0
          ; external_perimeter_extrusion_width = 0.6
          ; external_perimeter_speed = 30
          ; external_perimeters_first = 0
          ; extra_loading_move = -2
          ; extra_perimeters = 1
          ; extruder_clearance_height = 20
          ; extruder_clearance_radius = 20
          ; extruder_colour = ""
          ; extruder_offset = 0x0
          ; extrusion_axis = E
          ; extrusion_multiplier = 1
          ; extrusion_width = 0.6
          ; fan_always_on = 0
          ; fan_below_layer_time = 60
          ; filament_colour = #29B2B2
          ; filament_cooling_final_speed = 3.4
          ; filament_cooling_initial_speed = 2.2
          ; filament_cooling_moves = 4
          ; filament_cost = 11
          ; filament_density = 1
          ; filament_diameter = 1.75
          ; filament_load_time = 0
          ; filament_loading_speed = 28
          ; filament_loading_speed_start = 3
          ; filament_max_volumetric_speed = 0
          ; filament_minimal_purge_on_wipe_tower = 15
          ; filament_notes = ""
          ; filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6"
          ; filament_settings_id = ApolloX
          ; filament_soluble = 0
          ; filament_toolchange_delay = 0
          ; filament_type = ABS
          ; filament_unload_time = 0
          ; filament_unloading_speed = 90
          ; filament_unloading_speed_start = 100
          ; fill_angle = 0
          ; fill_density = 15%
          ; fill_pattern = triangles
          ; first_layer_acceleration = 0
          ; first_layer_bed_temperature = 85
          ; first_layer_extrusion_width = 0.63
          ; first_layer_height = 0.22
          ; first_layer_speed = 10
          ; first_layer_temperature = 240
          ; gap_fill_speed = 30
          ; gcode_comments = 0
          ; gcode_flavor = reprap
          ; gcode_label_objects = 0
          ; high_current_on_filament_swap = 0
          ; host_type = duet
          ; infill_acceleration = 0
          ; infill_every_layers = 1
          ; infill_extruder = 1
          ; infill_extrusion_width = 0.68
          ; infill_first = 0
          ; infill_only_where_needed = 0
          ; infill_overlap = 0%
          ; infill_speed = 60
          ; interface_shells = 0
          ; layer_gcode =
          ; layer_height = 0.16
          ; machine_max_acceleration_e = 10000,5000
          ; machine_max_acceleration_extruding = 1500,1250
          ; machine_max_acceleration_retracting = 1500,1250
          ; machine_max_acceleration_x = 9000,1000
          ; machine_max_acceleration_y = 9000,1000
          ; machine_max_acceleration_z = 500,200
          ; machine_max_feedrate_e = 120,120
          ; machine_max_feedrate_x = 500,200
          ; machine_max_feedrate_y = 500,200
          ; machine_max_feedrate_z = 12,12
          ; machine_max_jerk_e = 2.5,2.5
          ; machine_max_jerk_x = 10,10
          ; machine_max_jerk_y = 10,10
          ; machine_max_jerk_z = 0.2,0.4
          ; machine_min_extruding_rate = 0,0
          ; machine_min_travel_rate = 0,0
          ; max_fan_speed = 30
          ; max_layer_height = 0
          ; max_print_height = 400
          ; max_print_speed = 80
          ; max_volumetric_speed = 0
          ; min_fan_speed = 15
          ; min_layer_height = 0.07
          ; min_print_speed = 5
          ; min_skirt_length = 0
          ; notes =
          ; nozzle_diameter = 0.6
          ; only_retract_when_crossing_perimeters = 0
          ; ooze_prevention = 0
          ; output_filename_format = [input_filename_base].gcode
          ; overhangs = 1
          ; parking_pos_retraction = 92
          ; perimeter_acceleration = 0
          ; perimeter_extruder = 1
          ; perimeter_extrusion_width = 0.6
          ; perimeter_speed = 60
          ; perimeters = 3
          ; post_process =
          ; print_host = 192.168.1.24
          ; print_settings_id = ABS
          ; printer_model =
          ; printer_notes =
          ; printer_settings_id = D9
          ; printer_technology = FFF
          ; printer_variant =
          ; printer_vendor =
          ; printhost_apikey =
          ; printhost_cafile =
          ; raft_layers = 0
          ; remaining_times = 0
          ; resolution = 0
          ; retract_before_travel = 2
          ; retract_before_wipe = 0%
          ; retract_layer_change = 1
          ; retract_length = 3.5
          ; retract_length_toolchange = 10
          ; retract_lift = 0
          ; retract_lift_above = 0
          ; retract_lift_below = 0
          ; retract_restart_extra = 0
          ; retract_restart_extra_toolchange = 0
          ; retract_speed = 100
          ; seam_position = aligned
          ; serial_port =
          ; serial_speed = 250000
          ; silent_mode = 1
          ; single_extruder_multi_material = 0
          ; single_extruder_multi_material_priming = 1
          ; skirt_distance = 2
          ; skirt_height = 1
          ; skirts = 2
          ; slice_closing_radius = 0.049
          ; slowdown_below_layer_time = 20
          ; small_perimeter_speed = 30
          ; solid_infill_below_area = 70
          ; solid_infill_every_layers = 0
          ; solid_infill_extruder = 1
          ; solid_infill_extrusion_width = 0.68
          ; solid_infill_speed = 50
          ; spiral_vase = 0
          ; standby_temperature_delta = -5
          ; start_filament_gcode = "; Filament gcode\n"
          ; start_gcode = G28 ; home all axes\n;G29 homing?\n\nG1 Z2 F8000 ; lift nozzle\nG1 X150 Y10\n
          ; support_material = 1
          ; support_material_angle = 0
          ; support_material_auto = 0
          ; support_material_buildplate_only = 0
          ; support_material_contact_distance = 0.2
          ; support_material_enforce_layers = 0
          ; support_material_extruder = 1
          ; support_material_extrusion_width = 0.52
          ; support_material_interface_contact_loops = 0
          ; support_material_interface_extruder = 1
          ; support_material_interface_layers = 1
          ; support_material_interface_spacing = 0
          ; support_material_interface_speed = 100%
          ; support_material_pattern = rectilinear
          ; support_material_spacing = 5
          ; support_material_speed = 60
          ; support_material_synchronize_layers = 0
          ; support_material_threshold = 0
          ; support_material_with_sheath = 1
          ; support_material_xy_spacing = 50%
          ; temperature = 240
          ; thin_walls = 1
          ; threads = 4
          ; toolchange_gcode =
          ; top_fill_pattern = rectilinear
          ; top_infill_extrusion_width = 0.68
          ; top_solid_infill_speed = 30
          ; top_solid_layers = 4
          ; travel_speed = 150
          ; use_firmware_retraction = 0
          ; use_relative_e_distances = 0
          ; use_volumetric_e = 0
          ; variable_layer_height = 1
          ; wipe = 1
          ; wipe_into_infill = 0
          ; wipe_into_objects = 0
          ; wipe_tower = 0
          ; wipe_tower_bridging = 10
          ; wipe_tower_rotation_angle = 0
          ; wipe_tower_width = 60
          ; wipe_tower_x = 180
          ; wipe_tower_y = 140
          ; wiping_volumes_extruders = 70,70
          ; wiping_volumes_matrix = 0
          ; xy_size_compensation = 0
          ; z_offset = 0
