    Straightforward way to setup a servo motor for extruder
    Other control boards
    • code7undefined
      code7
      I've reviewed some of the servo motor posts in the form and am wondering if someone can give advice on the most straightforward way to setup a "52 RPM Premium Planetary Gear Motor w/Encoder" for the extruder on a 3D printer with the Duet 2 Wifi board. I'm looking for the most robust and quick way to implement this and cost is not a concern.
      This is the motor I would like to interface with. Thanks
      https://www.servocity.com/52-rpm-premium-planetary-gear-motor-w-encoder
      Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
      tooundefined 1 Reply Last reply Reply Quote 0
      • tooundefined
        too @code7
        @code7 you will need to get a Servo driver that accepts step/direction inputs, then you can connect it to the duet through the large expansion connector.
        Configuration will be just like a normal stepper.
        Cartesian Duet3+Raspberry pi 4 with 5x 1XD using servo drives printing mortars and concrete
        • code7undefined
          code7
          @too It sounds like you might be talking about a stepper motor vs. a servo motor? Is there a controller that you would recommend that has worked well for you?
          • tooundefined
            too @code7
            @code7 nope, I'm definitely talking about servos 🙂
            We use a bit heavier industrial equipment, so we use these bad boys here:
            As for other drivers, just search for "servo driver" at your trusted electronics supplier, and you will find boxes similar to this:
