configerator question
hi all, on the latest configerator it has a box with the option of firmware(2.04 etc). does this mean that firmware will be uploaded as well with the files?
thank you, Rod
No, it's just to set the compatibility of the generated files. So you can generate config files for older firmware, if need be.
no it changes to generated config for that version.
thankyou for your prompt reply
cheers, Rod
