    Maestro LCD-12864 RepRapD1scount config
    Firmware installation
    366
    • Peter_Oundefined
      Peter_O
      I'm running a Maestro 1.0 with Firmware 2.03 (2019-06-13b2).
      A tronxy "LCD-12864 RepRapD1scount" is connected and works with mudcruzr's setup. (Thanks for that!)
      Best config seems to be
      M918 P1 E-2 F2000000
      Display and rotary are working fine so far.
      But moving the knob one notch moves the cursor two menu positions. Balancing the rotary between notches makes available the menu position in between.
      E-1 should be right, but with E-1 the cursor blurrs and marks two menu positions.
      Any idea?
      • Vetiundefined
        Veti
        @Peter_O said in Maestro LCD-12864 RepRapD1scount config:
        Try E-4
        • Peter_Oundefined
          Peter_O
          Did. Jumps erratically.
            This post is deleted!
            • Vetiundefined
              Veti
              please try with the latest firmware.
                dc42 administrators @Veti
                E-4 should be correct.
                • Peter_Oundefined
                  Peter_O
                  @Veti, now I've updated to latest FW set of version 2, 2.05 and latest release 1.8 of mudcruzr's menus.
                  That makes no difference.
                  @David, Ok. So E-4 be it.
                  Overall it's usable. Thanks. 🙂
                  Just for information:
                  It misses a click or steps backward maybe 1 in 5 clicks.
                  With E-2 it was stepping two positions per click reliably. And hoovering between steps make the position in between acessible.
                  Mainly I'm using the web interface of course.
                  But the LCD comes handy for homing or having a look at the temperatures.
                  Wishing you a relaxed and quiet Holiday season and a happy and peaceful New Year!
                  • Vetiundefined
                    Veti
                    that would indicate a problem with the encoder, but a missed step does not seem to be much of a problem.
                      @Veti said in Maestro LCD-12864 RepRapD1scount config:
                      I agree. Both contacts would have to be bouncing simultaneously for that to happen. The firmware can handle any amount of bounce from one contact, but not both together.
                      • Peter_Oundefined
                        Peter_O
                        Ok. Maybe I'll swap the encoder for a quality part sometime. Thanks!
