    VIN under-voltage event after connecting panelduedisplay
    874
    • vjsaini00undefined
      vjsaini00
      I am continuously getting this error, maybe my 7inch display corrupted my board.plz someone help me. I reset my duet 2 wifi board but no luck.
      Here is mine m122 report
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3SW-6J1FD-3SD6L-TVVZF
      Used output buffers: 3 of 24 (8 max)
      Static ram: 25680
      Dynamic ram: 92488 of which 120 recycled
      Exception stack ram used: 268
      Never used ram: 12516
      Tasks: NETWORK(ready,764) HEAT(blocked,912) MAIN(running,3808) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:33 ago, cause: power up
      Last software reset at 2019-12-23 16:01, reason: User, spinning module GCodes, available RAM 11468 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 16.7, current 20.4, max 20.4
      Supply voltage: min 2.4, current 3.9, max 32.2, under voltage events: 2524, over voltage events: 0, power good: no
      Date/time: 2019-12-23 17:48:27
      Cache data hit count 107398782
      Slowest loop: 2.07ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 15.48ms; fastest: 0.00ms
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address ec:fa:bc:31:78:aa
        WiFi Vcc 3.34, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 24336
        WiFi IP address 192.168.1.21
        WiFi signal strength -43dBm, reconnections 0, sleep mode modem
        Socket states: 2 0 0 0 0 0 0 0
      • Vetiundefined
        Veti
        @vjsaini00 said in VIN under-voltage event after connecting panelduedisplay:
        what power supply have you got? the duet max supported is 25v.
        how are you connecting the paneldue? via ribbon cable or 4 way cable?
        the duet does not need the paneldue for operation. so disconnect it for now.
          vjsaini00
          Thanks for replying, I am using 24v supply. I had already disconnected the paneldue, but still getting this error
            vjsaini00
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
            Static ram: 25712
            Dynamic ram: 92836 of which 164 recycled
            Exception stack ram used: 272
            Never used ram: 12088
            Tasks: NETWORK(ready,628) HEAT(blocked,912) MAIN(running,3736) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:28:28 ago, cause: power up
            Error status: 0
            MCU temperature: min 23.4, current 25.6, max 26.3
            Supply voltage: min 4.0, current 4.1, max 32.2, under voltage events: 111785, over voltage events: 6, power good: no
            Date/time: 2019-12-23 21:34:17
            Slowest loop: 6.28ms; fastest: 0.05ms
            === DDARing ===
            Segments left: 0
            === Network ===
            Slowest loop: 15.45ms; fastest: 0.00ms
            • WiFi -
              WiFi Vcc 3.33, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 24056
              WiFi signal strength -29dBm, reconnections 0, sleep mode m
            • Vetiundefined
              Veti
              measure the voltage of the vin using a multimeter.
                vjsaini00
                it is 24.17 v
                • Vetiundefined
                  Veti
                  disconnect everything except vin and gnd and test again.
                    vjsaini00
                    I have already disconnected everything
                      vjsaini00
                      • Vetiundefined
                        Veti
                        what about the diagnostic leds? 3.3, 5v and vin. are they all lit up bright?
                          vjsaini00
                          yes perfectly
                            vjsaini00
                            • Vetiundefined
                              Veti
                              are you aware that you have a clone board?
                              you will have to wait for an answer from @dc42 as to which component has failed.
                              i remember dc42 saying that the vin is calculated based on the 3.3v line.
                              but your 3.3v line must be fine as the cpu is working.
                                vjsaini00
                                ok thanks, I will wait for that..👍
                                  vjsaini00
                                    vjsaini00
                                    THIS error shows up when duet 2 wifi connected to pc via usb
                                    "Error: short-to-ground reported by driver(s) 0 2 3 4
                                    Error: over temperature shutdown reported by driver(s) 0 2 3 4
                                    Warning: VIN under-voltage event (0.3V)
                                    12/24/2019, 12:10:23 AM Error: short-to-ground reported by driver(s) 0 1 2 3"
                                    Below are the diagnostics when duet 2 wifi connected through usb
                                    M122
                                    Static ram: 25712
                                    Tasks: NETWORK(ready,764) HEAT(blocked,912) MAIN(running,3800) IDLE(ready,160)
                                    Owned mutexes:
                                    Last reset 00:00:37 ago, cause: power up
                                    Error status: 0
                                    MCU temperature: min 18.1, current 19.3, max 19.4
                                    Supply voltage: min 0.2, current 0.2, max 28.0, under voltage events: 603, over voltage events: 0, power good: no
                                    Driver 0: temperature-shutdown! short-to-ground standstill, SG min/max not available
                                    Driver 1: temperature-shutdown! short-to-ground standstill, SG min/max not available
                                    Driver 2: temperature-shutdown! short-to-ground standstill, SG min/max not available
                                    Driver 3: temperature-shutdown! short-to-ground standstill, SG min/max not available
                                    Driver 4: temperature-shutdown! short-to-ground standstill, SG min/max not available
                                    Date/time: 2019-12-24 00:10:15
                                    Cache data hit count 127774597
                                    Slowest loop: 1.08ms; fastest: 0.05ms
                                    === DDARing ===
                                    Segments left: 0
                                    === Network ===
                                    Slowest loop: 15.40ms; fastest: 0.00ms
                                    • WiFi -
                                      WiFi flash size 4194304, free heap 24144
                                      WiFi signal strength -44dBm, reconnections 0, sleep mode modem
                                      Either the clone board is garbage, or the power supply is garbage. Either way, I think you're frying your board.
                                      • Vetiundefined
                                        Veti
                                        i think you have fried the drivers and they are now leaking current onto the 3.3v line.
                                        vjsaini00undefined 1 Reply Last reply Reply Quote 0
                                          vjsaini00 @Veti
                                          @Veti
                                          is there any way to confirm it?
                                          • Vetiundefined
                                            Veti
                                            that should not happen
