    Correction travel distance
    CNC
    • lobyundefined
      loby
      Hi, I am trining to setup up the travel distance of the axis. I measured e.g. on the Z axis 0.1 mm to less travel distance if I travel 5mm down. So I want to setup the duet2 to compensate this 0.1 mm in the right way.
      I did not find a hint for that how to do. Could someone help me?
      Thank you.
      Best regards
      Gerd
      • A Former User?
        A Former User
        The right way would depend on what the problem is.
        How are you driving the axis, motor, coupling, belt, screw.
        An any case its either backlash which I don't think the Duet an compensate for or your effective gearing is a bit off and you need to adjust the M92 steps/mm setting
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M92_Set_axis_steps_per_unit
        • lobyundefined
          loby
          Perfect! That was the keyword I am looking for. Steps/mm? I looked in the config and didn't recognized the setting. After you named it I saw it immediately.
          Now the travel distance is perfect!
          Thank you so much for the speed help!
          Best regards,
          Gerd
