Solved Building RRFlibraries 'atomic_uint8_t' does not name a type
Trying to set up Eclipse to build the firmware and hit a snag that I can't seem to iron out.
I've checked out the following (in git bash, on windows,
after giving up on linuxlinux build works after all, still curious what I messed up here?)cd /c/eclipse/firmware git clone https://github.com/dc42/CoreNG.git --branch dev git clone https://github.com/dc42/CANlib.git git clone https://github.com/dc42/RRFLibraries.git --branch dev git clone https://github.com/dc42/FreeRTOS.git git clone https://github.com/dc42/RepRapFirmware.git --branch v3-dev git clone https://github.com/dc42/DuetWiFiSocketServer.git
Screenshot to verify (if I've missed something between juggling versions)
It fails with
01:57:28 **** Clean-only build of configuration SAME70_RTOS for project RRFLibraries **** make -j4 clean rm -rf ./src/RTOSIface/RTOSIface.o ./src/Math/Isqrt.o ./src/General/IP4String.o ./src/General/IPAddress.o ./src/General/SafeStrtod.o ./src/General/SafeVsnprintf.o ./src/General/StringFunctions.o ./src/General/StringRef.o ./src/General/Strnlen.o ./src/RTOSIface/RTOSIface.d ./src/Math/Isqrt.d ./src/General/IP4String.d ./src/General/IPAddress.d ./src/General/SafeStrtod.d ./src/General/SafeVsnprintf.d ./src/General/StringFunctions.d ./src/General/StringRef.d ./src/General/Strnlen.d libRRFLibraries.a 01:57:28 Build Finished. 0 errors, 0 warnings. (took 295ms) 01:57:29 **** Incremental Build of configuration SAME70_RTOS for project RRFLibraries **** make -j4 all Building file: ../src/RTOSIface/RTOSIface.cpp Building file: ../src/Math/Isqrt.cpp Building file: ../src/General/IP4String.cpp Building file: ../src/General/IPAddress.cpp Invoking: Cross G++ Compiler Invoking: Cross G++ Compiler Invoking: Cross G++ Compiler arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q21__ -DRTOS -I"C:\eclipse\firmware\FreeRTOS\src\include" -I"C:\eclipse\firmware\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -O3 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib -Wundef -Wdouble-promotion -fsingle-precision-constant "-Wa,-ahl=RTOSIface.s" -MMD -MP -MF"src/RTOSIface/RTOSIface.d" -MT"src/RTOSIface/RTOSIface.o" -o "src/RTOSIface/RTOSIface.o" "../src/RTOSIface/RTOSIface.cpp" Invoking: Cross G++ Compiler arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q21__ -DRTOS -I"C:\eclipse\firmware\FreeRTOS\src\include" -I"C:\eclipse\firmware\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -O3 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib -Wundef -Wdouble-promotion -fsingle-precision-constant "-Wa,-ahl=Isqrt.s" -MMD -MP -MF"src/Math/Isqrt.d" -MT"src/Math/Isqrt.o" -o "src/Math/Isqrt.o" "../src/Math/Isqrt.cpp" arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q21__ -DRTOS -I"C:\eclipse\firmware\FreeRTOS\src\include" -I"C:\eclipse\firmware\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -O3 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib -Wundef -Wdouble-promotion -fsingle-precision-constant "-Wa,-ahl=IP4String.s" -MMD -MP -MF"src/General/IP4String.d" -MT"src/General/IP4String.o" -o "src/General/IP4String.o" "../src/General/IP4String.cpp" arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q21__ -DRTOS -I"C:\eclipse\firmware\FreeRTOS\src\include" -I"C:\eclipse\firmware\FreeRTOS\src\portable\GCC\ARM_CM7\r0p1" -O3 -Wall -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib -Wundef -Wdouble-promotion -fsingle-precision-constant "-Wa,-ahl=IPAddress.s" -MMD -MP -MF"src/General/IPAddress.d" -MT"src/General/IPAddress.o" -o "src/General/IPAddress.o" "../src/General/IPAddress.cpp" In file included from ../src/RTOSIface/RTOSIface.cpp:8:0: ../src/RTOSIface/RTOSIface.h:352:7: error: 'atomic_uint8_t' in namespace 'std' does not name a type std::atomic_uint8_t numReaders; // MSB is set if a task is writing or write pending, lower bits are the number of readers ^~~~~~~~~~~~~~ ../src/RTOSIface/RTOSIface.h:353:21: error: 'std::atomic_uint8_t' has not been declared static_assert(std::atomic_uint8_t::is_always_lock_free); ^~~~~~~~~~~~~~ ../src/RTOSIface/RTOSIface.h: In constructor 'ReadWriteLock::ReadWriteLock()': ../src/RTOSIface/RTOSIface.h:336:5: error: class 'ReadWriteLock' does not have any field named 'numReaders' : numReaders(0), writeLockOwner(nullptr) ^~~~~~~~~~ ../src/RTOSIface/RTOSIface.cpp: In member function 'void ReadWriteLock::LockForReading()': ../src/RTOSIface/RTOSIface.cpp:244:17: error: 'numReaders' was not declared in this scope uint8_t nr = numReaders; ^~~~~~~~~~ ../src/RTOSIface/RTOSIface.cpp: In member function 'void ReadWriteLock::ReleaseReader()': ../src/RTOSIface/RTOSIface.cpp:269:5: error: 'numReaders' was not declared in this scope --numReaders; ^~~~~~~~~~ ../src/RTOSIface/RTOSIface.cpp: In member function 'void ReadWriteLock::LockForWriting()': ../src/RTOSIface/RTOSIface.cpp:293:16: error: 'numReaders' was not declared in this scope uint8_t nr = numReaders; ^~~~~~~~~~ ../src/RTOSIface/RTOSIface.cpp:306:9: error: 'numReaders' was not declared in this scope while (numReaders != 0x80) ^~~~~~~~~~ ../src/RTOSIface/RTOSIface.cpp: In member function 'void ReadWriteLock::ReleaseWriter()': ../src/RTOSIface/RTOSIface.cpp:321:3: error: 'numReaders' was not declared in this scope numReaders = 0; ^~~~~~~~~~ ../src/RTOSIface/RTOSIface.cpp:323:12: error: 'numReaders' was not declared in this scope else if ((numReaders & 0x7F) != 0) ^~~~~~~~~~ ../src/RTOSIface/RTOSIface.cpp: In member function 'void ReadWriteLock::DowngradeWriter()': ../src/RTOSIface/RTOSIface.cpp:336:3: error: 'numReaders' was not declared in this scope numReaders = 1; ^~~~~~~~~~ Finished building: ../src/General/IPAddress.cpp make: *** [src/RTOSIface/subdir.mk:20: src/RTOSIface/RTOSIface.o] Error 1 make: *** Waiting for unfinished jobs.... Finished building: ../src/General/IP4String.cpp Finished building: ../src/Math/Isqrt.cpp 01:57:30 Build Failed. 12 errors, 0 warnings. (took 1s.58ms)
Am I using the wrong branches of something or the wrong tools?
GNU Tools ARM Embedded\8 2018-q4-major
For all targets except SAMC21, type std::atomic_uint8_t should be defined in file <atomic> which is #included at line 24 of RTOSIface.h. On my Windows build system, that file is located in folder C:\Program Files (x86)\GNU Tools ARM Embedded\8 2018-q4-major\arm-none-eabi\include\c++\8.2.1.
HTH David
Thanks, i found the included file and the include statement doesn't throw an error so a little puzzled as to whats wrong. It does build for Duet2RTOS but not Duet3V06.
No big deal, Kudos to oliof for this thread aiding in getting it built under Debian. Will update thread if I stumble onto the solution for Windows
@bearer said in Building RRFlibraries 'atomic_uint8_t' does not name a type:
I build under Windows and I don't have any build problems. Could it be picking up an old include file on your machine?
you sir are a saint and a genius!
I thought I had removed the old stuff from building PanelDue, but I clearly know far too little about eclipse and cross compiling in general.
RRF(libraries) built without issues!
