RRF3 Deactivate External Trigger
  • Hi @dc42,
    Did i miss something or is there no replacement for M581 S-1 for RRF3?
    In RRF2 i was disabling the external triggers on my lower endstops during homing.
    Since in RRF 3 the S Parameter was removed it seems not to be possible any more.
    Do you have any suggestions?
    Calling an empty trigger#.g - file would be an ugly option. Maybe there is some better idea.
    Thanks.
  • Activate:
    M581 P"e0stop+e1stop" T2 C1
    Deactivate:
    M581 P"nil" T2
  • @Danal
    Thank you for your fast reply.
    Deactivating the trigger by M581 P"nil" seems to do the job.
    Unclear to me is which triggers are deactivated.
    I could image following situation (Pin names in the example are not real names)
    M581 P"es1" T0 C0 ; es1 always leads to an emergency stop if activated
    M581 P"es2" T0 C1; es2 is only activated during a print
    M581 P"nil" T0 ; are both triggers deactivated?
  • The Tn is the key.
    And... in your example, the requested definitions are in conflict. You've asked for Trigger 0 to be both "always" and "only print".
    I believe the firmware would take the last one. I am absolutely certain it will trigger only one "es2", because if you want both the syntax would be P"es1+es2".
    So, if you ran those first two statements, I am 100% certain that you would only define a single trigger, named T0, I am 100% certain only pin ES2 would trigger (ES1 would be ignored), and I am 98% certain that it would trigger only during a print.
    Therefore the "nil" would deactivate the one and only T0.
  • Thanks @Danal.
    You opened my eyes. Since your last post i thought it is possible to have multiple triggers for the same number.
    Double checked this in the code. Tn is definitely the key.
    So i have to change my emergency stop triggers a little bit otherwise they are not fully functional.
