DWC2 Uploading large Gcode files results in network error
  • I seem to be unable to upload larger >3 MB with DWC2, I always get a network error.
    I have no issues uploading the same file when I revert to DWC1.
    I'm running 2.05 (just went from 2.04 in case that was the problem) but I have the same issues.
    I know the wifi signal strength is on the 'low' side, but if I have no issues uploading in DWC1, then why can't I upload with DWC2?
    Board: Duet WiFi 1.0 or 1.01
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
    Duet WiFi Server Version: 1.23
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.0 or 1.01
    Board ID: 08DAM-999TL-MQ4S8-6J1FL-3SN6S-9QBRX
    Used output buffers: 1 of 24 (10 max)
    Static ram: 25712
    Dynamic ram: 92696 of which 304 recycled
    Exception stack ram used: 272
    Never used ram: 12088
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3800) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:07:28 ago, cause: software
    Last software reset at 2020-01-08 11:06, reason: User, spinning module GCodes, available RAM 12396 bytes (slot 2)
    Error status: 0
    Free file entries: 10
    SD card 0 detected, interface speed: 12.0MBytes/sec
    SD card longest block write time: 166.0ms, max retries 0
    MCU temperature: min 32.0, current 32.6, max 34.0
    Supply voltage: min 12.7, current 12.8, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-01-09 10:32:44
    Cache data hit count 1403011763
    Slowest loop: 53.11ms; fastest: 0.06ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Bed heaters = 0 -1 -1 -1, chamberHeaters = 2 -1
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 189.51ms; fastest: 0.01ms
    HTTP sessions: 1 of 8
    - WiFi -
    Network state is running
    WiFi firmware version 1.23
    WiFi MAC address 5c:cf:7f:2b:eb:38
    WiFi Vcc 3.38, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 25936
    WiFi IP address 192.168.0.56
    WiFi signal strength -67dBm, reconnections 0, sleep mode modem
    I saw that in the above M122, the SD card longest block write time: 166.0ms is pretty long, but I did a few subsequent M122 and the longest block write time is 0ms
    Please try to upgrade to DWC 2.0.5. The new version no longer relies on the "axios" library for HTTP calls but uses native AJAX calls instead, so I hope this will solve your problem.
    @jrjones88 said in DWC2 Uploading large Gcode files results in network error:
    That just means you haven't written to the SD card between sending the previous M122 command and the current one.
  • Hello,
    I have the same problem, DUET WIFI RRF 3.0 and DWC 2.0.6.
    Unable to upload large files from both the web and CURA, I have to go back to DWC1.
    @danzaywer What browser are you using and what is the error message you get?
    @danzaywer said in DWC2 Uploading large Gcode files results in network error:
    Please check (using M122) that you are running version 1.23 of the WiFi module firmware.
  • @dc42
    • WiFi -
      Failed messages: pending 0, notready 0, noresp 1
      WiFi MAC address 80:7d:3a:3f:f5:64
      WiFi Vcc 3.42, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 18600
      WiFi IP address 192.168.101.136
      WiFi signal strength -57dBm, reconnections 0, sleep mode modem
      Socket states: 2 2 0 0 0 0 0 0
  • @chrishamm
    I tried both with chrome and with edge
    browser give me this:
    CURA give me this:
    Both error messages mean that the connection is interrupted while an upload is in progress. You can try to change your WiFi channel and check if that makes a difference. Also, if you can, move your printer closer to your WiFi access point and check if you can upload files then.
    This guide may give you further hints on how to resolve this problem.
  • Thank you,
    in the evening I will carry out checks on the channel. The printer is a fair distance from the access point.
    With the current situation and DWC1 I have no problem and the upload is very fast.
    Are you able to get a WireShark trace of a failed upload? That might help us diagnose the problem.
  • @dc42
    I can try
  • @chrishamm
    Ok, I changed the channel but it didn't help, I moved the printer 1 meter sideways and now I can upload a 30 MB file without errors. I intend to restore the previous position and analyze with wireshark to understand the cause of the problem, the printer is about 5 meters from an ubiquiti mounted on the ceiling without obstacles, in both positions.
    Thanks for the support, as soon as I have the wireshark trace I will upload it.
  • @chrishamm said in DWC2 Uploading large Gcode files results in network error:
    I've haven't been able to test it for a while, but I've since upgraded to 2.0.7 and while I do have a higher success rate, the odd time the upload still fails.
    I've attached 3 wireshark traces of failed uploads here: https://1drv.ms/u/s!AgTPtiCYHi3hh8oNZ5d6wYz7VkdVzQ?e=pKpMUd
  • Moderator
    Welcome to the vaugeries of wireless.
    @jrjones88 Thanks for the Wireshark dumps but I'm afraid they show that your PC sends bad packets and not the Duet. There are a couple of out-of-order packets from your AsRock network card and some other retransmissions.
    I suggest you perform the steps on this site and if it does not help, try upgrading the drivers of your network card.
    In addition, I tried to upload a 160MB test file from Firefox and Chromium to my Duet WiFi. None of the transfers failed with DWC 2.0.7.
  • I am having the same problem, just started out of nowhere.
    worked perfect for months, 3 days after installing RRF3 having problems.
  • Moderator
    @Benny I suggest starting a new thread and include details about your setup including what board, what firmware and DWC version exactly. Also the output of M122 and your config file for good measure.
  • No worries think I have sorted, Reset everything, deleted cache and repaired sd card.
    Not sure what fixed it.
