    Anet A8 BLTouch and Bed heater problems
    Firmware installation
    1
    1
    132
    • HowardTheDuckundefined
      HowardTheDuck
      config.g
      I am setting up a Duet 2 Wifi on my Anet A8 and just updated the firmware to the most recent version.
      On https://configtool.reprapfirmware.org/Start when I select Firmware version: 3.0 or later:
      on the page I/O Mapping, under Z-Probe the Pin "PWM Control Channel (BLTouch only)" defaults to "(not assigned)"; should I change this, and if so to what?
      on the page "Endstops" the BLTouch option is no longer available;
      Also, when running the "Check Heater Functionality" test in setup, the bed heater rises about 2-3 degrees above ambient, then generates the following error message and stops:
      Error: Heating fault on heater 0, temperature rising much more slowly than the expected 1.8°C/sec
      That expected rate seems very unrealistic to me, using my stock board it would typically take at least 5 minutes to reach 70C from ambient which is closer to 0.1-0.2C per second.
      How can I fix this?
