topic_unsolved RRF3, find where a pin is used.
Is there an easy way to track down where a pin is assigned? I'm getting
M950 F1 C"1.out6"
Error: Pin 1.out6 is not freeAnd several others... and I really don't see what's assigning board 1 pin out6.
Figured out the underlying problem with the already assigned pin. Second expansion on wrong firmware.
Still curious if there is a way to "dump all pins" or similar.
@Danal said in RRF3, find where a pin is used.:
Currently the pin table records what mode each pin is used in but not which device is using it.
