    Heated bed no longer controllable after software update
    Beta Firmware
    1
    • brendonundefined
      brendon
      I updated a Duet 3 via ssh
      sudo apt-get update
      sudo apt-get upgrade
      and am now no longer able to see/control the bed temperature. I am unsure of what software versions I had been using, but I've included a portion of config.g and the current output from M122. Before the update the machine was running fine. The hot end is still working as expected.
      M308 S0 P"0.temp0" Y"thermistor" T97700 B4619 C9.743561e-8 R2200   ; define bed temperature sensor
      M308 S1 P"0.temp1" Y"thermistor" T100000 B4725 C7.06e-8            ; define E0 temperature sensor
      M950 H0 C"out0" T0 Q100                                            ; heater 0 uses the bed_heat pin, sensor 0
      M950 H1 C"out1" T1                                                 ; heater 1 uses the e0_heat pin and sensor 1
      RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0 running on Duet 3 MB6HC
      Board ID: 08DJM-956L2-G43S4-6J1FA-3SJ6T-1B6QH
      Used output buffers: 1 of 32 (7 max)
      Static ram: 152720
      Dynamic ram: 149872 of which 0 recycled
      Exception stack ram used: 216
      Never used ram: 90408
      Tasks: ETHERNET(blocked,844) NETWORK(ready,1984) HEAT(blocked,1200) CanReceiv(suspended,3808) CanSender(suspended,1476) CanClock(blocked,1424) TMC(blocked,212) MAIN(running,4452) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:01:37 ago, cause: software
      Last software reset at 2020-01-16 19:06, reason: User, spinning module LinuxInterface, available RAM 90408 bytes (slot 0)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 33.6, current 34.0, max 34.1
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: standstill, reads 22282, writes 14 timeouts 0, SG min/max 0/0
      Driver 1: standstill, reads 22283, writes 14 timeouts 0, SG min/max 0/0
      Driver 2: standstill, reads 22283, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: standstill, reads 22287, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: standstill, reads 22285, writes 14 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 22285, writes 14 timeouts 0, SG min/max 0/0
      Date/time: 2020-01-16 19:08:03
      Slowest loop: 2.66ms; fastest: 0.09ms
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon* is ready with "M122" in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      spi is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.46ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      - Ethernet -
      State: 2
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 389, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 14ms ago
      RX/TX seq numbers: 35121/2998
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v1.2.3.0
      Code buffer space: 4096
      Configured SPI speed: 2000000 Hz
      Full transfers per second: 0.71
      Current Duet3 version:
      RepRapFirmware for Duet 3 MB6HC 3.4.0 beta 6 (2021-11-06)
      Duet Web Control 3.4.0-b6
      • brendonundefined
        brendon
        Nevermind, I found the issue in the release notes.
        Duet 3 users: there is no longer a default bed heater. To use Heater 0 as the bed heater, put M140 H0 in config.g (later in config.g than your M950 H0 command).
