Solved Accidentally deleted SD card
Hello pretty new to the duet world, i accidentally deleted all files on the sd card, and have no clue what to do. I searched around duet dozuki, but tbh i got even more confused. I am using a duet 2 wifi v1.04
Thanks
Babisco -
beyond trying data recovery tools on the sd card, your best bet is to download duet web control and use the online configurator to generate new config.
(or possibly grab this and adjust as needed https://github.com/T3P3/Duet/raw/master/Duet2/SD Card Contents/SD_Card_Contents.zip )
Thanks I used the sd card content and it worked
You are lucky if you solved the problem so simply.
This post is deleted!
