    Can't connect with USB
    Firmware installation
    1.3k
    • Arcsonundefined
      Arcson
      (EDIT-Grammar)
      I'm a new DuetWifi owner.
      Installing in a BigBox Dual.
      The first time booting up was fine, I got the wifi web server up and running but when I updated to latest firmware I lost connectivity to the web server. When I plugged back in the usb it would repeatedly connect/disconnect. Eventually I flashed the board and used SAM-BA to re-install the firmware, but it still repeatedly connect/disconnects. I am really frustrated, I had everything working and now nothing is working.
      Here is Pronterface readout while trying to follow another thread that seemed to have the same problems as me.
      "Connecting…
      Printer is now online.
      M552 S1
      SENDING:M552 S1
      [ERROR] Can't read from printer (disconnected?) (SerialException): call to ClearCommError failed
      [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed ([Error 22] The device does not recognize the command.)
      [ERROR] Disconnecting after 4 failed writes.
      Disconnected.
      M115
      [ERROR] Printer is not online.
      Reset.
      Connecting…
      M105
      SENDING:M105
      ok T:B:23.4
      M997 S1
      SENDING:M997 S1
      Trying to connect at 460800 baud:
      success
      Disconnected.
      Connecting...
      M105
      SENDING:M105
      ok T:B:23.5
      M997 S1
      SENDING:M997 S1
      failed
      Trying to connect at 230400 baud:
      success
      Erasing 290848 bytes...
      Erase failed
      Error: Installation failed due to timeout error
      [ERROR] Error: Installation failed due to timeout error
      M997 S2
      SENDING:M997 S2
      success
      Erasing 3125248 bytes…
      Erase failed
      M552 S1
      SENDING:M552 S1
      Disconnected."
      The DuetWifi is on my local wifi. I've tried using a USB cable and I get the same thing.
      What am i doing wrong?
        Try commenting out the M552 S1 command in config.g, then see if you get a reliable USB connection. If so, download a fresh copy of DuetWiFiServer.bin and rename it to exactly that on the SD card, then install it using M997 S1.
        • Arcsonundefined
          Arcson
          Thank you for the quick response,
          I re-downloaded DuetWiFiServer.bin placed it as you requested.
          At first Pronterface seemed to be working but the wifi still never came up.
          Connecting…
          M997 S1
          SENDING:M997 S1
          success
          Uploading file...
          5% complete
          10% complete
          15% complete
          20% complete
          25% complete
          30% complete
          35% complete
          40% complete
          45% complete
          50% complete
          55% complete
          60% complete
          65% complete
          70% complete
          75% complete
          80% complete
          85% complete
          90% complete
          95% complete
          Upload successful
          M552 S1
          SENDING:M552 S1
          WiFi server starting up
          I could re-check all my wiring and look for a short, but again I was on the webserver when it crashed the first time and I haven't change anything.
          Is there anything else I can do?
          Thanks,
          • Arcsonundefined
            Arcson
            I am really at a loss on what to do, I can get my printer to work by using the sd card and the touch screen, but I purchased this board for the computer and wifi control. Do I need to return the board for a new one? I was fairly sure this was a software issue. I really would like next step options to get my printer back online.
              Can you confirm that you are using version 1.18.1 main firmware and version 1.03-ch DuetWiFiFirmware? If yes, ask your supplier for a replacement Duet.
