    Why in home XY different G1 is not execute in my code?
    CNC
    1.2k
    • Clementundefined
      Clement
      ; Why in home XY different G1 is not execute in my code?
      ; Duet2 Firmware v2.03 Cartesian CNC
      G90
      M669 K0
      M453 S0
      M550 P"CBeam"
      M586 P0 S1
      M586 P1 S0
      M586 P2 S0
      M569 P0 S1
      M569 P1 S1
      M569 P2 S1
      M584 X0 Y1 Z2
      M350 X16 Y16 Z16 I1
      M92X800.0 Y800.0 Z800.0 ;400step/rev
      M566 X300.0 Y300.0 Z300.0
      M203 X2000.0 Y2000.0 Z2000.0
      M201 X150.0 Y150.0 Z150.0
      M906 X800 Y800 Z800 I30
      M579 X0.988 Y0.988 Z0.988
      M84 S10
      M18
      M208 X0:280 Y0:347 Z0:137
      M564 S1 H1
      M574 X2 Y2 Z2 S0
      M558 P0 H5 F120 T2160
      M140 H-1
      M563 P0
      M911 S21.0 R23.0 P"G91G1Z3F1000"
      ; homex
      G91
      G21
      G1 Z20 H1 F500
      G1 X-300 H1 F1800
      G1 X5 F300
      G1 X-10 H1 F300 ;this is not execute?
      G1 Z-20 H1 F500 ;this is not execute?
      G92 X0
      G90
      ; homey
      G91
      G21
      G1 Z20 H1 F500
      G1 Y-360 H1 F1800
      G1 Y9 F300
      G1 Y-10 H1 F300 ;this is not execute?
      G92 Y0
      G90
      ; homez
      G91
      G21
      G1 Z180 H1 F1800
      G1 Z-5 F300
      G1 Z9 H1 F300
      G1 Z-120 F1400
      G92 Z-120
      G90
      ; homeall
      G91
      G21
      G1 Z170 H1 F1800
      G1 Z-5 F300
      G1 Z9 H1 F300
      G1 X-300 Y-360 H1 F1800
      G1 X-5 Y-5 F300
      G1 X10 Y10 H1 F300
      G1 Z-120 F1400
      G92 X0 Y0 Z-120
      G90
      • Danalundefined
        Danal
        @Clement-B said in Why in home XY different G1 is not execute in my code?:
        ; homex
        G91
        G21
        G1 Z20 H1 F500
        G1 X-300 H1 F1800
        G1 X5 F300
        G92 X0
        G90
        It seems rather odd that you have endstop/probe moves for Z in your homeX. Perhaps the Z moves do not need the H1?
        Using dashboard "homex" button, or G28 X command, does the X axis show as homed after all this executes?
        • A Former User?
          A Former User
          that would be because Y and Z are already at the limit switch presumably? or you need to reverse the sign due to relative moves?
          Clementundefined 1 Reply Last reply Reply Quote 0
            Phaedrux Moderator @Clement
            You appear to be missing a space after M92
            • Clementundefined
              Clement
              Thank for your answer, but
              Are spaces required between commands?
              This is a question.
              • A Former User?
                A Former User @Clement
                It certainly isn't for all commands, but it does aid readability and doesn't hurt.
                • Danalundefined
                  Danal
                  Spaces are not required between coordinates. X0Y0 or X0 Y0 is fine.
                  Spaces are not technically required anywhere per the NIST standard, and similarly not required by the Duet parser.
                  However, it is a very strong best practice to have one in between the "command word" that begins the line and everything else on the line.
                  Clementundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  • Clementundefined
                    Clement @A Former User
                    @Danal said in Why in home XY different G1 is not execute in my code?:
                    I use DuetPanel,
                    Control | I execute "homex.g" . The command G1 X-10 and G1 Z-20 is not execute, but for Z this not in the limit place?
                    G1 X-10 H1 F300
                    G1 Z-20 H1 F500
                    With command G28 X, this work correctly.
                    • Clementundefined
                      Clement @Danal
                      @Danal
                      Thank for your info
                      • Danalundefined
                        Danal
                        Just as a future note:
                        Running the macro as a macro IS NOT the same as having the macro invoked via G28 or a DWC "home" button.
                        Having it auto invoked by G28 or home button will mark X as "homed". Running as a 'regular' macro will not. There may be other more subtle differences.
                        Clementundefined 2 Replies Last reply Reply Quote 0
                        • Clementundefined
                          Clement @Danal
                          @Danal
                          Thank for this info
                          • Clementundefined
                            Clement @Danal
                            @Danal
                            Here, I don't use macro file but the button homeX which calls the "homex.g" file,
                            I apologize for not being clear enough.
                            • Danalundefined
                              Danal
                              Perfect, that is the right way.
                              Votre langue maternelle est-elle française?
                                dc42 administrators @Danal
                                Correct; except that a space is needed before an E parameter. Otherwise the E gets taken as an exponent for the previous number. Example:
                                M98 Z400 E100 ; Z steps/mm is 400, E steps/mm is 100
                                M98 Z400E100  ; Z steps/mm is 400 * 10^100
                                Clementundefined 1 Reply Last reply Reply Quote 1
                                • Clementundefined
                                  Clement @Danal
                                  @Danal
                                  Oui
                                  • Clementundefined
                                    Clement @dc42
                                    Thank for this info
                                    • Clementundefined
                                      Clement
                                      I think I don't understand the M208 command well.
                                      I think the commands in homex and homey are due to my misunderstanding of M208 ... G92
                                      There are a few things that I don't quite understand.
                                      The lengths of the axes of my CNC are: X = 280 Y = 347 Z = 137mm
                                      For the LSW to be touched by the Z axis by command G1 Z180 H1 F1800.
        X G1 X-300 H1 F1800.
        Y G1 Y-360 H1 F1800.
                                      After these 3 commands, my router is at the left limit on the X axis (at the X- limit)
        base limit on the Y axis (at the Y- limit)
        high limit on the Z axis (at the Z + limit)
                                      I want my Home position to be there for the X and Y axes.
                                      But for Z, I want the position to be 120mm below the Z limit. So Z-120mm.
                                      I want my movements work only within the limits of my CNC.
                                      How I write this in Gcode in my config.g and home_.g files
                                      And then, if possible, translate my RRF2.03 version into RRF3 version.
                                      ; This my code + commentary *****************************************************************
                                      ; Duet2 Firmware RRF2.03
                                      ; ---Generales---
                                      G90 ; Absolue (A space is needed before an E parameter)
                                      M669 K0 ; Knnn Kinematics type: 0=Cartesian
                                      M453 S0 ; S0=CNC S0=default spindle (S0-S3 spindle max)... Here: M3/M4/M5 control the pins defined for the milling device
                                      ; ---Network---
                                      M550 P"CBeam" ; Machine name
                                      M551 P" " ; Set password
                                      M552 S1 P172.16.1.74 ; S1=Enable network -> Ethernet - Change IP Address to suit
                                      M586 P0 S1 ; Enable HTTP S1=enable
                                      M586 P1 S0 ; Disable FTP
                                      M586 P2 S0 ; Disable Telnet
                                      M540 PBE:64:4B:54:52:5C ; MAC Address (Use when more 1 duet on the same network). Change only last byte: 00..FF BE:64:4B:54:52:5C -> 172.16.1.74
                                      ; ---Drives---
                                      M569 P0 S1 ; Drive P0.1 DIR: S0=Backwards - S1=Forwards +
                                      M569 P1 S1 ; Drive P0.2
                                      M569 P2 S1 ; Drive P0.3 Zdn=- Zup=+
                                      M584 X0 Y1 Z2 ; Associer Driver & Axe
                                      ; ---Axis_Config---
                                      M350 X16 Y16 Z16 I1 ; Microstepping (16=with interpolation)
                                      ; C_Beam -> leadscreew=diameter=8mm, pitch=2mm. 8mm!=diameter->(8mm/rev)/pitch=4starts 4starts=kind of screw
                                      M92 X800.00 Y800.00 Z800.00 ; steps/mm 0.9degre/step=400step/rev 400*16ustep=6400 6400/4=800step/mm
                                      M566 X300.00 Y300.00 Z300.00 ; Speed change 500mm/min Speed start at 300 = minimum speed
                                      M203 X2000.00 Y2000.00 Z2000.00 ; Speed max <-G0 2520mm/min
                                      M201 X150.00 Y150.00 Z150.00 ; Acceleration 150mm/s^2
                                      M906 X800 Y800 Z800 I30 ; 2400mA max, 800mA/bobine & motor idle 30%) StepMotor: JUGETEK_57H56M-2804A=1.68A(85%=good) 0.9degre 1.2N.m Nema23
                                      ;M906 X2400 Y2400 Z2400 I100 ; Current https://blog.prusaprinters.org/calculator/
                                      M84 S10 ; Idle->I30 After 10sec of inactivity -> current 30%
                                      ;M579 X0.988 Y0.988 Z0.988 ; Calibration 300mm=demand size/303.6mm=reel size -> M579 Cartesian mode
                                      M18 ; Motor->OFF G0-G3 Motor->ON
                                      ; ---Axis_Limits---
                                      M208 X0:280 Y0:347 Z0:137 ; Xmin:max X->279.4mm=11" Y->346.075mm=13 5/8" Z->136.525mm=5 3/8"<-CBeam z0->LSW Limit min=S1 max=S0 Zup=+ Zdn=-
                                      M564 S1 H1 ; S1=use LSW S0=not use LSW H1=set Home before move H0=no set Home
                                      ; ---Fans---
                                      ;M950 F0 C"out7" Q500 ; Create fan 0 on pin out7 and set its frequency
                                      ;M106 P0 S0 H-1 ; Set fan 0 value. Thermostatic control is turned off
                                      ; ---Endstops---
                                      M574 X2 Y2 Z2 S0 ; Set active low endstops. X0=none X1=low_end X2=high_end S0=active_LOW_enstop_input S1=active_HIGH_enstop_input
                                      ; ---Probes---
                                      M558 P0 H5 F120 T2160 ; P0=no probe. Disable Z probe but set la hauteur de plonger, probe speed & travel speed
                                      ; ---Heaters---
                                      M140 H-1 ; Negative value = disable heater_1 bed
                                      ; ---Lasers---
                                      ;M452 ; If M452 -> G0 G1:S=0-255 Value power Laser: 0-255
                                      ; ; H0=no_action H1=LSW+M208->limite H3=LSW+position_axe->limite H2=individuel axe (no_CNC)
                                      ; ---Tools---
                                      M563 P0 ; P0= Tool0 Need defind allway
                                      ;G10 P0 X0 Y0 Z0 ; Set Tool0 axis offsets
                                      ;G10 P0 R0 S0 ; Set initial Tool0 active and standby temperatures to 0C
                                      ; ---Others---
                                      M911 S21.0 R23.0 P"G91 G1 Z3 F1000" ; Save info if power loss. PowerSupply:24V 21V=stop 23V=restart (Z up de 3mm en relatif)
                                      ;M501 ; Load config-override.g (Stored Parameters)
                                      ;M98 P"customconfig.g" ; Execute custom config settings
                                      ; X->279.4mm=11" Y->346.075mm=13 5/8" Z->136.525mm=5 3/8"<-CBeam X=300 Y=360 Z=150
                                      ; homex.g
                                      G91 ; Relative
                                      G21 ; Units to mm
                                      G1 Z20 H1 F500 ; Zup (protect break bit)
                                      G1 X-300 H1 F1800 ; Move to LSW X & stop
                                      G1 X5 F300 ; Go back for ajuste more precisely X at LSW
                                      G1 X-10 H1 F300 ; Move to LSW X & stop
                                      G1 Z-20 H1 F500 ; Zdn
                                      G90 ; Absolute
                                      G92 X0 ; Set Home Position
                                      ; homey.g
                                      G91 ; Relative
                                      G21 ; Units to mm
                                      G1 Y-360 H1 F1800 ; Move to LSW Y & stop
                                      G1 Y5 F300 ; Go back for ajuste more precisely Y at LSW
                                      G1 Y-10 H1 F300 ; Move to LSW Y & stop
                                      G90 ; Absolute
                                      G92 Y0 ; Set Home Position
                                      ; homez.g
                                      G91 ; Relative
                                      G21 ; Units to mm
                                      G1 Z180 H1 F1800 ; Move to LSW Z & stop Zup=+
                                      G1 Z-5 F300 ; Go back for ajuste precisely at LSW
                                      G1 Z-120 F1400 ; Go Home
                                      G90 ; Absolute
                                      G92 Z-120 ; Set Home Position
                                      ; homeall.g
                                      G91 ; Relative
                                      G21 ; Units to mm
                                      G1 Z170 H1 F1800 ; Move to LSW Z & stop Zup=+
                                      G1 Z9 H1 F300 ; Move to LSW Z & stop
                                      G1 X-300 Y-360 H1 F1800 ; Move to LSW X & stop
                                      G1 X-5 Y-5 F300 ; Go back for ajuste more precisely X at LSW
                                      G1 X10 Y10 H1 F300 ; Move to LSW X & stop
                                      G90 ; Absolute
                                      G92 X0 Y0 Z-120 ; Set Home Position
                                      Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                        The minima value from M208 is set as the axis position when the endstop is triggered. So in your homex and homeY files you don't need to use the G92 X0 and G92 Y0 because those values are already set as soon as the endstop is triggered.
                                        For your Z axis, your M208 says the Z minima is 0 and maxima is 137, and then in your homing file you home to z max and the position is set as 137, then you move it down by -120, which would place the Z axis at (137-120=17) and then set the position to be actually as -120, which tells the firmware it's below the minima.
                                        It's not super clear to me yet from your description what you actually want to happen. Perhaps a picture of the machine marked up with your intention?
                                          ; homez.g
                                          G91 ; Relative
                                          G21 ; Units to mm
                                          G90 ; Absolute
                                          Also, your homez file differs from your homeall file. In homez you move to the endstop, back off 5mm, then back off another 120, putting the actual position at -125.
                                          But in homeall you hit the endstop, back off 5mm, hit the endstop again, and then move down 120. You'll get an unintentionally different position between homez and homeall because of that.
                                          • Clementundefined
                                            Clement @Phaedrux
                                            @Phaedrux
                                            ok, I see this,
                                            thank
