    M0 H1 running stop.g instead of cancel.g
    Beta Firmware
    1
    • gtj0undefined
      gtj0
      @dc42 Your comment in https://forum.duet3d.com/post/127608 reminded me of this...
      When I have a print in progress and send M25 followed by M0 H1, stop.g is run, instead of cancel.g.
      Here's what it looks like from the DCS:
      [debug] Processing G1 X35.657 Y90.842
      [debug] Waiting for execution of G1 X35.671 Y90.661
      [debug] Processing G1 X35.671 Y90.661
      [debug] File: Sent G1 X35.657 Y90.842, remaining space 420, needed 36
      [debug] File: Sent G1 X35.671 Y90.661, remaining space 384, needed 36
      [debug] IPC#58: Got new UNIX connection, checking mode...
      [debug] IPC#58: Command processor added
      [debug] IPC#58: Received command SimpleCode
      [debug] Waiting for execution of M25
      [debug] Processing M25
      [debug] HTTP: Sent M25, remaining space 1516, needed 20
      [info] Print paused at file position 2611. Reason: User
      [debug] Print has been paused at byte 2611
      [debug] Cancelled G1 X44.466 Y112.347
      [debug] Cancelled G1 X44.286 Y112.322
      [debug] Cancelled G1 X43.366 Y112.153
      [debug] Cancelled G1 X43.131 Y112.096
      [debug] Cancelled G1 X42.208 Y111.808
      [debug] Cancelled G1 X41.982 Y111.722
      [debug] Cancelled G1 X41.101 Y111.326
      [debug] Cancelled G1 X40.060 Y110.714
      [debug] Cancelled G1 X40.887 Y111.213
      [debug] Cancelled G1 X39.861 Y110.576
      [debug] Cancelled G1 X39.101 Y109.980
      [debug] Cancelled G1 X38.920 Y109.820
      [debug] Cancelled G1 X38.237 Y109.137
      [debug] Cancelled G1 X38.076 Y108.956
      [debug] Cancelled G1 X37.480 Y108.195
      [debug] Cancelled G1 X36.859 Y107.196
      [debug] Cancelled G1 X36.772 Y107.036
      [debug] Cancelled G1 X37.343 Y107.996
      [debug] Cancelled G1 X36.534 Y106.547
      [debug] Cancelled G1 X36.462 Y106.380
      [debug] Cancelled G1 X36.141 Y105.534
      [debug] Cancelled G1 X36.084 Y105.361
      [debug] Cancelled G1 X35.938 Y104.837
      [debug] Cancelled G1 X35.898 Y104.661
      [debug] Cancelled G1 X35.729 Y103.741
      [debug] Cancelled G1 X35.645 Y102.596
      [debug] Cancelled G1 X35.700 Y103.501
      [debug] Cancelled G1 X35.642 Y102.476
      [debug] Cancelled G1 X35.642 Y91.384
      [debug] Cancelled G1 X35.642 Y91.324
      [debug] Cancelled G1 X35.657 Y90.842
      [debug] Cancelled G1 X35.671 Y90.661
      [info] Executing nested macro file pause.g on channel HTTP
      [debug] ==> Starting code: M25
      [debug] Waiting for execution of ; pause.g
      [debug] Processing ; pause.g
      [debug] Waiting for execution of ; called when a print from SD card is paused
      [debug] Completed ; pause.g
      [debug] Processing ; called when a print from SD card is paused
      [debug] Completed ; called when a print from SD card is paused
      [debug] Waiting for execution of M83; relative extruder moves
      [debug] Processing M83; relative extruder moves
      [debug] Waiting for execution of G1 E-5 F600; retract 5mm of filament
      [debug] Processing G1 E-5 F600; retract 5mm of filament
      [debug] HTTP: Sent M83; relative extruder moves, remaining space 1516, needed 20
      [debug] HTTP: Sent G1 E-5 F600; retract 5mm of filament, remaining space 1480, needed 36
      [debug] Waiting for execution of G91; relative positioning
      [debug] Processing G91; relative positioning
      [debug] Waiting for execution of G1 Z5 F600; lift Z by 5mm
      [debug] HTTP: Sent G91; relative positioning, remaining space 1460, needed 20
      [debug] Processing G1 Z5 F600; lift Z by 5mm
      [debug] Waiting for execution of G90
      [debug] HTTP: Sent G1 Z5 F600; lift Z by 5mm, remaining space 1424, needed 36
      [debug] Processing G90
      [debug] HTTP: Sent G90, remaining space 1404, needed 20
      [debug] Completed M83; relative extruder moves
      [debug] Completed G1 E-5 F600; retract 5mm of filament
      [debug] Completed G91; relative positioning
      [debug] Completed G1 Z5 F600; lift Z by 5mm
      [debug] HTTP: Finished macro file pause.g
      [debug] Completed G90
      [info] HTTP: Finished macro file pause.g
      [debug] Completed M25 =>
      Printing paused at X45.2 Y112.4 Z10.0
      [debug] HTTP: ==> Starting code: M25 =>
      [debug] IPC#58: Connection closed
      [debug] IPC#59: Got new UNIX connection, checking mode...
      [debug] IPC#59: Command processor added
      [debug] IPC#59: Received command SimpleCode
      [debug] Waiting for execution of M0 H1
      [debug] Processing M0 H1
      [info] Cancelled print file
      [debug] HTTP: Sent M0 H1, remaining space 1508, needed 28
      [info] Cancelled printing file 0:/gcodes/sr.gcode, print time was 0h 0m
      [info] Executing nested macro file stop.g on channel HTTP
      [debug] ==> Starting code: M0 H1
      [debug] HTTP: Finished macro file stop.g
      [info] HTTP: Finished macro file stop.g
      [debug] Completed M0 H1
      [debug] HTTP: ==> Starting code: M0 H1
      [debug] IPC#59: Connection closed
      • gtj0undefined
        gtj0
        Oh, @chrishamm This looks like a DSF issue. If I run M0 H1 from the Duet USB Serial port, it runs cancel.g. I'll open an issue on gitgub.
