    RRF 3.0 + Bed Heating issue
    Firmware installation
    • A Former User
      A Former User last edited by
      Board: Duet2Wifi:
      After migrating to RRF3.0 - I am getting a heating error every time I try to heat up the bed.
      Error: Heating fault on heater 0, temperature rising much more slowly than the expected 1.8°C/sec
      While this certainly is a nice thermal runaway feature. The tolerance seem a bit off, for a bed.
      I am sure I have misconfigured something.
      Any ideas?
      Config:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 17 2020 20:55:58 GMT+0100 (Central European Standard Time)
      M550 P"Tronds Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes backwards
      M92 X81.35 Y80.95 Z400.00 E804.76 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I10 ; set motor currents (mA) and motor idle factor in per cent
      M84 S1 ; Set idle timeout
      M208 X400 Y400 Z500 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X38 Y-6 Z2.15 ; set Z probe trigger value, offset and trigger height
      M557 X20:380 Y20:380 S20 ; define mesh grid
      M143 H0 S80 ; set temperature limit for heater 0 to 80C
      ; Custom settings
      M572 D0 S0.45 ; Pressure advance causes the extruder drive position to be advanced or retarded during printing moves by an additional amount (0.8% of tube (56cm) = 0.448 proportional to the rate of extrusion. At the end of a move when the extrusion rate is decreasing, this may result in the extruder drive moving backwards (i.e. retracting). Therefore, if you enable this feature, you may need to reduce the amount of retraction you use in your slicing program to avoid over-retraction.
      T0 ; select first tool
        That error should go away if you tune the bed heater using M303.
