    Reume after m601 pause not performing as expected
    Duet Web Control
    duet 3 hc6 3 extruder 1 hotend pause.g resume.g duet web control
    2.2k
    • tsunaminautundefined
      tsunaminaut
      So I have a duet 3 hc6 hooked up too an ender 5 with 3 extruders into 1 hotend rig. I'm using Duet web control on a raspberry pi 4 hooked up via serial cable to the duet 3 board. I'm using perusa slicer as I like how it creates purge towers but have run into the following issue. I want to pause the print to change out the color on an extruder then resume printing. I use persua slicer to insert m601 at layer 2 it does pause althought seems to ignore my pause.g script, but then when I resume it just kinda extrudes a bit of fillament and puts the nozzle back on the print and then pauses again.After 3 days trying to research this I cant for the life of me figure out how to get it to resume printing. I will attach my pause.g and resume.g below in the hopes someone cant point out what I'm doing wrong or maybe suggest a better way to go about this with duet hardware. (I used to use cura slicer with the pause at height on marlin firmware mks gen L board without any issues).
      Thanks for your attention!
      ; pause.g
      ; called when a print from SD card is paused
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Dec 22 2019 16:11:22 GMT-0500 (Eastern Standard Time)
      M83 ; relative extruder moves
      G1 E-10 F3600 ; retract 10mm of filament
      G91 ; relative positioning
      G1 Z5 F360 ; lift Z by 5mm
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      ; resume.g
      ; called before a print from SD card is resumed
      G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
      G1 R1 X0 Y0 ; go back to the last print move
      G1 E10 F3600 ; extrude 10mm of filament
      build info below
      Board: Duet 3 MB6HC (MB6HC)
      DSF Version: 1.1.0.5
      Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0beta12 (2019-11-02b1)
      Danalundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal @tsunaminaut
        You want M226 for pause.
        M601 is not defined for Duet/RepRap firmware. Nor in Marlin, etc. It is a Prusa only thing.
        tsunaminautundefined 1 Reply Last reply Reply Quote 1
          tsunaminaut @Danal
          @Danal Sorry Yes ribbon cable, g code is below
          G1 F1200.000
          G1 X36.795 Y43.354 E9.52794
          G1 X36.771 Y43.475 E9.53077
          G1 X36.747 Y43.597 E9.53311
          G1 X36.730 Y43.835 E9.53663
          G1 X36.730 Y56.927 E9.69288
          G1 X36.763 Y57.252 E9.69678
          G1 X36.782 Y57.347 E9.69873
          G1 X36.818 Y57.402 E9.70003
          G1 X36.835 Y57.424 E9.70055
          G1 X36.975 Y57.585 E9.70432
          G1 X39.744 Y60.379 E9.76438
          G1 X39.759 Y60.399 E9.76469
          G1 X39.763 Y60.407 E9.76480
          G1 X39.767 Y60.411 E9.76485
          G1 X39.771 Y60.414 E9.76490
          G1 X39.822 Y60.441 E9.76544
          M106 S229.5
          G1 Z1.700 F7800.000
          M117 PAUSE HAPPENS HERE
          M601
          G1 E4.76544 F2400.00000
          G92 E0
          G1 Z2.700 F7800.000
          G1 X39.542 Y43.201
          G1 Z1.700
          G1 E5.00000 F2400.00000
          G1 F900.000
          G1 X39.322 Y43.292 E5.00808
          G1 X39.201 Y43.385 E5.01323
          G1 X39.043 Y43.004 E5.02717
          G1 X39.503 Y43.004 E5.04273
          G1 X39.531 Y43.142 E5.04748
          G1 E0.04748 F2400.00000
          G92 E0
            tsunaminaut
            That was it! I just needed to insert M226! thanks Danal!!!! 3 days I was dreading having to ask someone lol!
              The other command you can use for this purpose is M600. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M600_Filament_change_pause.
                tsunaminaut
                So I was wrong that m226 didnt resolve the behavior. Basically it seemed to use the pause and resume scripts but then it squirts some plastic on the spot the pause happens circles around and goes back to pause. another oddity it seemed to retract T1 when I was using T0 although none of the gcode appears to have a tool change in it.
                https://www.youtube.com/watch?v=3XeIBw7q12c
                • Danalundefined
                  Danal
                  I don't use pause a lot, so I could be wrong... but... this looks to me like two different pause commands:
                  One is "at byte" and the other is "at Xnnn Ynnn Znnn". Any chance the slicer has two different pause things enabled?
                  What happens if you hit resume print again?
                  tsunaminautundefined 1 Reply Last reply Reply Quote 0
                    tsunaminaut @Danal
                    @Danal I checked the slicer and there is no custom gcode in it aside from my tool change gcode which shouldn't be coming into play as I'm not changing tools in this test. When I click on resume, it does what that video shows every time over and over and over, like it starts running the code right before the pause m226 so just gets stuck in a loop, I checked the slicer and the only thing I'm seeing is the right click on layer 3 where I inserted M226. (had the same experience with m600 but I don't have any custom filament change g code file saved so am assuming m600 defaults to running my pause.g and resume.g). I checked the gcode file and it doesn't appear to have anything other then M226 in it either.
                      dc42 administrators @tsunaminaut
                      It may be a firmware issue. Are you running your Duet 3 with or without a Raspberry Pi connected?
                        tsunaminaut @dc42
                        @dc42 Running it with Duet web control through a raspberry pi 4 on the SBC 26 pin header.
                          @tsunaminaut said in Reume after m601 pause not performing as expected:
                          Thanks, I suspect it is to do with the way that DSF is handling M226 and M600.
                            tsunaminaut @dc42
                            @dc42 Is there a way of generating a log to see what commands are being sent by the pi? I'm pretty sure manually pressing the pause and resume buttons inside the web interface work as they should, it feels like upon resume its starting up again right before the pause in the code.
                            • Danalundefined
                              Danal
                              ssh to the pi, then:
                              sudo journalctl -u duetcontrolserver will dump the entire log; if to terminal with a 'more' like interface; if pipe or redirect, entire log.
                              sudo journalctl -fu duetcontrolserver with 'f' will follow (like tail -f) the log. You can leave this running while you try various commands, if you just want to see the log.
                              • chrishammundefined
                                chrishamm administrators
                                Please upgrade your DSF version and check if the problem perists. The print management has changed significantly since v1.1.0.5.
                                Duet software engineer
                                  tsunaminaut @chrishamm
                                  @chrishamm updated as follows
                                  DSF Version: 1.2.3.0
                                  https://www.youtube.com/watch?v=Pl8WEcgjPe8
                                  Now M226 does the pause.g script when I hit resume it goes back to the print and throws error below
                                  1/19/2020, 12:31:44 PM M24
                                  Printing resumed
                                  1/19/2020, 12:31:44 PM Printing paused at X114.2 Y113.1 Z1.3
                                  1/19/2020, 12:31:44 PM Error: G1 has thrown an exception: [AggregateException] One or more errors occurred. (A task was canceled.)
                                  1/19/2020, 12:31:44 PM Cancelled printing file 0:/gcodes/PRINTER_CANAL_v2PauseTestNew3.gcode, print time was 0h 2m
                                    chrishamm administrators @tsunaminaut
                                    @tsunaminaut I'm sorry you're still having an issue with that version. I believe this is fixed in DSF 1.2.3.1 which is available on the unstable package feed. To activate it, replace stable with unstable in /etc/apt/sources.list.d/duet3d.list and run a regular system update (sudo apt-get update && sudo apt-get upgrade).
                                      @chrishamm Im now on
                                      DSF Version: 1.2.3.1
                                      Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.0 (2020-01-03b3)
                                      The issue continues, it appears to be fixed on 1 single extruder print but once I put a pause in a print that has multiple extruders it goes back to doing the same thing as in the video from the above post.
                                      1/19/2020, 7:59:14 PM M24
                                      Printing resumed
                                      1/19/2020, 7:58:05 PM Printing paused at X72.4 Y117.9 Z0.5
                                      1/19/2020, 7:58:02 PM M24
                                      Printing resumed
                                      1/19/2020, 7:57:43 PM Printing paused at X72.4 Y117.9 Z0.5
                                      1/19/2020, 7:57:40 PM M24
                                      Printing resumed
                                      1/19/2020, 7:57:31 PM Printing paused at X72.4 Y117.9 Z0.5
                                      1/19/2020, 7:57:28 PM M24
                                      Printing resumed
                                      1/19/2020, 7:57:28 PM Printing paused at X72.4 Y117.9 Z0.5
                                        I've prepared another in DSF 1.2.4 which I will release shortly. It will allow you to pause prints wherever you want.
                                        Thanks for reporting this!
                                          @chrishamm @chrishamm Appreciate you looking into this thanks! Ill report back if 1.2.4 fixes this!
                                            tsunaminaut @tsunaminaut
                                            I installed 1.2.4 and now m226 just freezes the printer and it wont resume, also oddly now when I attempt to print files it prints the purge tower base and then just drops the bed untill it bottoms out and starts skipping my z motor. On another test print it was printing a skirt and halfway around it it just started dropping my z as well. I'm having trouble figuring out how to go back to a stable build. would you be able to share a link to the documentation with instructions for that, it would be appreciated as my printer is now unusable.
