Reume after m601 pause not performing as expected
@tsunaminaut Starting to think I have a defective board. I will get a file to print then half an hour later the next time I try to print the same file it just freezes for no obvious reason 1 minute in theres no error codeit stays hot, is there some limit on the size of files a duet 3 hc 6 can handle?. Also I cant find any documentation on how to get back to a stable build do I need to wipe everything out and start over again?
1/28/2020, 1:17:00 AM M122
RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0 running on Duet 3 MB6HC
Board ID: 08DJM-956L2-G43S4-6JTDL-3SN6R-1S62G
Used output buffers: 1 of 32 (6 max)
Static ram: 152720
Dynamic ram: 150320 of which 12 recycled
Exception stack ram used: 536
Never used ram: 89628
Tasks: NETWORK(ready,1984) HEAT(blocked,1200) CanReceiv(suspended,3808) CanSender(suspended,1428) CanClock(blocked,1424) TMC(blocked,76) MAIN(running,4156) IDLE(ready,160)
Owned mutexes:
Last reset 00:12:16 ago, cause: software
Last software reset at 2020-01-28 06:04, reason: User, spinning module LinuxInterface, available RAM 89628 bytes (slot 3)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 10
MCU temperature: min 37.3, current 38.1, max 38.6
Supply voltage: min 24.7, current 24.9, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.3, current 12.3, max 12.4, under voltage events: 0
Driver 0: standstill, reads 4095, writes 30 timeouts 0, SG min/max 0/1023
Driver 1: standstill, reads 4096, writes 30 timeouts 0, SG min/max 0/1023
Driver 2: standstill, reads 4105, writes 21 timeouts 0, SG min/max 0/792
Driver 3: standstill, reads 4110, writes 17 timeouts 0, SG min/max 0/123
Driver 4: standstill, reads 4113, writes 14 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 4114, writes 14 timeouts 0, SG min/max 0/0
Date/time: 2020-01-28 06:17:04
Slowest loop: 3.62ms; fastest: 0.09ms
Hiccups: 0(0), FreeDm: 315, MinFreeDm: 310, MaxWait: 459429ms
=== MainDDARing ===
Scheduled moves: 349, completed moves: 289, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Heater 0 is on, I-accum = 0.2
Heater 1 is on, I-accum = 0.5
Segments left: 1
Movement lock held by null
http* is ready with "M122" in state(s) 0
telnet is idle in state(s) 0
file* is doing "G1 X153.694000 Y154.263000 E0.010930" in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon* is idle in state(s) 0
queue is idle in state(s) 0
lcd is idle in state(s) 0
spi is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1.13ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 0 of 8- Ethernet -
State: 0
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 2951, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 14ms ago
RX/TX seq numbers: 27156/21561
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 556/1940-0
=== Duet Control Server ===
Duet Control Server v1.2.4.0
File:
Buffered code: G1 X153.694 Y154.263 E0.01093
Buffered code: G1 X154.121 Y153.937 E0.03475
Buffered code: G1 X154.369 Y153.815 E0.01786
Buffered code: G1 X155.198 Y153.486 E0.05777
Buffered code: G1 X155.585 Y153.297 E0.02785
Buffered code: G1 X155.890 Y153.113 E0.02304
Buffered code: G1 X156.754 Y152.483 E0.06922
Buffered code: G1 X157.616 Y151.744 E0.07352
Buffered code: G1 X158.648 Y150.809 E0.09015
Buffered code: G1 X159.380 Y150.063 E0.06768
Buffered code: G1 X163.268 Y145.845 E0.37137
Buffered code: G1 X163.533 Y145.620 E0.02248
Buffered code: G1 X163.784 Y145.458 E0.01938
Buffered code: G1 X164.002 Y145.375 E0.01511
Buffered code: G1 X164.668 Y145.584 E0.04513
Buffered code: G1 X165.153 Y145.711 E0.03246
Buffered code: G1 X165.696 Y145.777 E0.03541
Buffered code: G1 X166.110 Y145.756 E0.02690
Buffered code: G1 X166.484 Y145.695 E0.02449
Buffered code: G1 X166.920 Y145.570 E0.02935
Buffered code: G1 X168.305 Y144.986 E0.09736
Buffered code: G1 X169.123 Y144.716 E0.05573
Buffered code: G1 X169.809 Y144.543 E0.04582
Buffered code: G1 X170.648 Y144.367 E0.05546
Buffered code: G1 X171.354 Y144.269 E0.04619
Buffered code: G1 X172.213 Y144.202 E0.05578
Buffered code: G1 X173.781 Y144.252 E0.10157
Buffered code: G1 X174.194 Y144.244 E0.02675
Buffered code: G1 X174.613 Y144.163 E0.02757
Buffered code: G1 X175.452 Y143.916 E0.05665
Buffered code: G1 X175.672 Y143.887 E0.01438
Buffered code: G1 X175.970 Y143.882 E0.01927
==> 1408 bytes
Code buffer space: 2156
Configured SPI speed: 2000000 Hz
Full transfers per second: 29.65
File /opt/dsf/sd/gcodes/18YodaRobes.gcode is selected, printing
Log shows the following
Jan 28 06:13:47 duet3 DuetControlServer[366]: [info] File: Finished macro file retractprobe.g
Jan 28 06:13:47 duet3 DuetControlServer[366]: [info] Height map loaded from file heightmap.csv
Print fails at this time so I am unable to cancel the print or abort it all I can do is emergency stop
Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Firmware halted
Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Firmware reset imminent
Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Emergency stop
Jan 28 06:17:38 duet3 DuetControlServer[366]: [warn] Resetting controller
Jan 28 06:17:38 duet3 DuetControlServer[366]: [info] Aborted print file - Ethernet -
@tsunaminaut Plesse share your sys directory and the file you have been trying to print. I have been unable to reproduce pause problems with 1.2.4 but I would really like to figure out why you still seem to have issues.
For now, you may have more success using the Duet 3 in standalone mode, i.e. with a microSD card installed and without a Raspberry Pi.
Was this ever resolved? I'm experiencing the same issue.
@smarshall Can you share some more info about what you're experiencing? hardware and firmware used? Perhaps starting a new thread with all your details would be best. Link back to this thread if you think it's related.
