    Magnetic rotating filament sensor "not working" errors
    Filament Monitor
    1
    • clegg78
      clegg78 last edited by clegg78
      So I am seeing continued issues with my new v1.7a Rotating magnet filament sensor. I have 2 of them installed and one of them seems to be constantly dropping out with:
      2020-01-18 10:44:35 Resume state saved
      2020-01-18 10:44:35 Extruder 0 reports sensor not working
      2020-01-18 10:44:41 Printing paused at X3.7 Y-101.1 Z4.2 U3.7
      2020-01-18 10:44:53 Printing resumed
      2020-01-18 11:02:54 Resume state saved
      2020-01-18 11:02:54 Extruder 0 reports sensor not working
      2020-01-18 11:03:03 Printing paused at X10.2 Y-124.8 Z5.0 U10.2
      This is regardless of if I even disable the sensor it seems.
      This is starting to cause a lot of issues with my prints and almost not worth even using the sensor these days.
      I ran M122 and i see this:
      Extruder 0: pos 253.48, errs: frame 13 parity 0 ovrun 0 pol 8 ovdue 0
      Extruder 1: pos 192.30, errs: frame 0 parity 0 ovrun 0 pol 37 ovdue 0
      They are connected to the CONN_LCD port. I have tested the wires and the connectors are good... To me this seems like an issue with the sensors or the CONN_LCD endstops. I am running v2.05 firmware.
      My M591 settings are: (I have the sample size huge and a big window for the ranges because I didnt want false positives)
      M591 D0 P3 C11 S1 R20:150 L25 E40
      M591 D1 P3 C11 S1 R20:150 L25 E40
      @T3P3Tony or @dc42 any insight in if there is something I should be doing differently? Is interference or EMI potentially an issue? the filament sensor wires run near the extruder/hotend wire runs.
      Also... what do each of the error names mean? Ovrun? Pol? OvDue?
      A geek designing and building his own custom IDEX printer from scratch as seen here: https://joekelly.co/3d/
      • clegg78
        For some reason the forum wont let me edit that post to fix a typo in the M591. :
        M591 D0 P3 C10 S1 R20:150 L25 E40
