    Add expected end time
    Duet Web Control wishlist
    • Nxt-1undefined
      Nxt-1
      I have been running some multi-day prints as of late. I consistently simulate the jobs before I print them, because I want to know when they will finish. Since the print times are so long, 35hr for example, it is not directly obvious to me when that actually is. Right now I use a website called hours from now calculator to check when the print will end the next day(s).
      I think it would be a nice addition to DWC2 to have and estimated end time displayed somewhere. The most important spot would be in the Status=>Estimations tab. It might also prove useful in the Jobs tab, just to see when a job should end, before you start it.
      Duet3D and delta printer enthousiast. Buildlog
      Looking for Duet3D configuration support, check out Nxt-3D
      • chrishammundefined
        chrishamm administrators
        It's already logged here: https://github.com/chrishamm/DuetWebControl/issues/196
        chrishamm created this issue in chrishamm/DuetWebControl
        open Display estimated end times again #196
        Duet software engineer
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • Nxt-1undefined
          Nxt-1 @chrishamm
          @chrishamm I should have checked the existing wishlist. I completely forgot that this was once a feature. Looking forward to it 🙂
