Additions to conditional system
Eventually I want to convert my manual set trigger height to run and complete automatically. To do this I ideally would like an average AVG function so that an average height could be obtained from 10 readings.
Is there a way to test if the system thinks that a filament is loaded?
Is it possible to expand M291 to include firmware objects? -
@appjaws said in Additions to conditional system:
Noted.
Filament monitors are not yet in the OM.
It already is. You will need to use the string concatenation operator.
@dc42, thanks for your help
This is the line I want to display on the screen.
M291 P"auto bed levelling using 3 Z motors completed deviation " ^ move.calibrationDeviation.deviation ^ "mm"
this is the error
Error: Bad command: M291 P"auto bed levelling using 3 Z motors completed deviation " ^ move.calibrationDeviation.deviation ^ "mm"and then I thought that it needed a ","
M291 P"auto bed levelling using 3 Z motors completed deviation ", ^ move.calibrationDeviation.deviation ^ "mm"
this is the error
Error: Bad command: M291 P"auto bed levelling using 3 Z motors completed deviation ", ^ move.calibrationDeviation.deviation ^ "mm"Not knowing much about code, I am stuck.
