    3.01-beta2+1 M25 during tool change
    Beta Firmware
    • Ntrackundefined
      Ntrack
      Might be a small issue with m25 during tool change in a sense that executes all the toolchanging files before pausing the print.
      G91				; relative moves
      G1 V300 H1 F1440                ; feed filament to finda sensor
      G92 V0				; force V to 0mm
      G1 V100 H1  F1440		; feed a bit more to reliably switch sensor
      G1 V30 H0 F2000			; feed filament to reach ptfe tube
      M400				; wait for moves to finish
      G90
      if !sensors.endstops[4].triggered
      	M25
      	M291 P"MMU loading failure detected" S2
      This is a small macro called during tpre.g and it is supposed to pause if V endstop is not triggered, but it will display the M291( which will stop and wait for OK) then it will execute tpost.g and only then will pause the print.
        That's correct, if you execute M25 when a tool change is in progress, it will complete the tool change first. M25 can only pause the print at the end of executing a complete line of GCode from the file being printed.
        • Ntrackundefined
          Ntrack
          Is there any other way to stop the tool change operation if something goes wrong?
            dc42 administrators @Ntrack
            @Ntrack said in 3.01-beta2+1 M25 during tool change:
            Only emergency stop at present.
            • Ntrackundefined
              Ntrack
              This post is deleted!
              • Ntrackundefined
                Ntrack
                I’ll have to wait for variables then.I think I have an idea how to do it using a variable.
