G29 pause before probe move
What I assume G29 does is
get a list of points to test and for each point- go to point in XY
- probe Z
- return to the previous Z position
I'm trying to use andromeda as a probe and since it's underneath the bed I need to configure the trigger to be very sensitive or it does not work. Problem I'm having is that cause trigger is sensitive it triggers on XY move so what I need is to have something like
foreach (pont){ G0X$xY$y G4S1 G30 }
this way the pause before probe allow sensor to "calm down" so that it properly detect the touch.
For e.g. I did this to my homez.g to get it to properly home:
; HOME Z WITH ANDROMEDA T0 G91 G0 Z5 F900 H2 G90 G0 X0Y0 F3000 G4S3 G30 G90
ideally, G29 can get same parameter as G4 (S for seconds P for milliseconds) only named differently as S and P are already used by G29 to modify how long the delay before probe move is executed.
The M558 R parameter is provided for this purpose.
hm, this looks like delay after it's triggered, not before the move is executed...
Z probe recovery time after triggering, default zero
anyhow, will test now
.. weird I was sure that parameter exist but was not able to find it, jumping between 3 and 2 is ... at least they are now both on same page
.. thanks
WORKS thanks!
Thanks, I've updated the description of the M558 R parameter.
great, thanks, looks like I'll have to figure out another way as andromeda is too unstable
