    Drives assigned as extruders don't work
    Beta Firmware
    rrf3 extruder motor driver
    • DoxfordCundefined
      DoxfordC
      I've got a Duet Wifi running RRF3 beta 3.
      If a drive is designated an extruder drive, either via M584 or by default, it ceases to function. The a stepper connected to the drive will buzz, and shaft will vibrate a bit, but it won't spin, even unloaded. However, if I reassign the same drive as an axis drive, say X, everything works like it should. This is with no hardware changes whatsoever. Conversely, reassigning a working axis drive as an extruder drive causes it to exhibit the symptoms outlined above.
      I've looked through the RRF3 docs and my config file, but I haven't been able to find anything that would cause this.
      Any help would be appreciated.
      weed2allundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal
        Please post your config.g
        • weed2allundefined
          weed2all @DoxfordC
          @DoxfordC nozzle need to have a certain temperature for the extruder motor start moving...does you preheat your nozzle when you try to move the extruder?
          https://www.thingiverse.com/weed2all/designs
          • Danalundefined
            Danal
            Or do an M302 P1 to allow cold extrudes.
            • DoxfordCundefined
              DoxfordC
              @weed2all @Danal :
              For all attempts to use the extruder, I have either used M302 or heated the hot end up to above 160 C. Additionally, it may be helpful to know that I am using the built-in stepper drivers. Moreover, all of the stepper motors for my machine are identical and configured the exact same way, except for the steps per mm.
              @Danal My current config.g:
              M550 PRMAXV32                              ; Printer name
              M555 P2                                    ; Gcode Output Type
              M552 S1                                    ; Enable Wifi
              M575 P1 B57600 S1                          ; PanelDue Comm Setup
              G21                                        ; Work in millimetres
              G90                                        ; Send absolute coordinates
              M569 P0 S0                                 ; Drive 0 goes forwards (X)
              M569 P1 S0                                 ; Drive 1 goes forwards (Y)
              M569 P2 S0                                 ; Drive 2 goes forwards (Z)
              M569 P3 S0                                 ; Drive 3 goes forwards (E0)
              M569 P4 S0                                 ; Drive 4 goes forwards (E1)
              M584 X0 Y1 Z2 E3:4						   ; Map drivers to motors.
              ; set endstop configuration (all endstops at high end, active high)
              M574 X1 S1 P"xstop"   ; X min active high endstop switch
              M574 Y1 S1 P"ystop"   ; Y min active high endstop switch
              M574 Z1 S1 P"zstop"   ; Z min active high endstop switch
              M665 R144 L291.06 B135 H400 X0 Y0 Z0       ; delta radius, diagonal rod length, printable radius and homed height
                                                         ; Y X Z are tower angle offsets
              M666 X0 Y0 Z0                              ; endstop offsets in mm
              M350 X16 Y16 Z16 E16:16 I1                 ; Set 16x microstepping w/ Interpolation
              M92 X200 Y200 Z200                         ; Set axis steps/mm
              M92 E178.4:178.4                           ; Set extruder steps/mm
              M906 X1200 Y1200 Z1200 E1200:1200 I50      ; Set motor currents (mA) and idle current %
              M201 X4200 Y4200 Z4200 E5000:5000               ; Accelerations (mm/s^2)
              M203 X18000 Y18000 Z18000 E18000:18000           ; Maximum speeds (mm/min)
              M566 X2000 Y2000 Z2000 E2000:2000               ; Maximum instant speed changes mm/minute
              M950 F0 C"fan0"
              M950 F1 C"fan1"
              M950 F2 C"fan2"
              M106 P0 S0 H-1                             ; Part Cooling Fan
              M106 P1 S0.5 H-1                           ; Case fan
              M106 P2 S1 T50 H1                          ; Heat sink fan
              M307 H0 B0                                 ; Heated Bed (H2)
              M308 S0 Y"thermistor" P"bed_temp" A"Bed temperature" T100000 B4388 R4700 H30 L0         ; Bed thermistor
              M950 H0 C"bed_heat" T0
              M308 S1 Y"thermistor" P"e0_temp" A"Hot end temperature" T100000 B4388 R4700 H30 L0         ; Hot end Thermistor
              M950 H1 C"e0_Heat" T1
              M563 P0 D0 H1                              ; Hot end (T0), drive (E0), heater (H1)
              G10 P0 S0 R0                               ; Hot end operating and standby temperatures
              ;Dual Extrusion Code
              ;M563 P1 D1 H1                              ; Hot end (T1), drive (E1), heater (H1)
              ;G10 P1 S0 R0                               ; Hot end (1) operating and standby temperatures
              M558 P5 C"^zprobe.in" I0 A5 S0.05 R0.4 H20 F2500 ; Strain gauge probe settings
              G31 P100 X0 Y0 Z-0.22                       ; Probe trigger and offset values
              M557 R140 S30                              ; defualt bed mapping
              M501                                       ; Load saved config values
              T0                                         ; Select Tool 0
              M375									   ; Load height map
              • DoxfordCundefined
                DoxfordC
                Well I "solved" the issue.
                I uncommented the dual extrusion code in my config.g, and the extruder started working.
                Bafflingly, I tried commenting out the dual extrusion code again to see if the issue came back, and it didn't. So I'm running the same config.g as above, with no other hardware or software modifications and the extruder works fine. I'd tried multiple config modifications before to no avail, and rebooted it many times prior to this. So I have no idea what the issue was, or why it disappeared, but it's gone now.
