    LED control like Fans
    Duet Web Control
    leds duet wifi duet web control
    943
    • Beersonundefined
      Beerson
      Hi there,
      I have a 4 Channel Mosfet Board with which I can control e RGBW LED strip. I connected it to the GPIO heater4...7 and can control it perfectly with the M42 gcode.
      Is it possible to configure the Outputs like a Fan output? I would like to control the colors by temperature like a fan.
      This way I would also have the Fan slider to control the different colors.
      Is this possible? How can I achieve that?
      • littlehobbyshopundefined
        littlehobbyshop
        In Firmware version 3.0 and later you can define the use of pins. Pretty sure you could do it with M950. Assuming Fan 0 is your hotend fan and Fan 1 is your layer fan, you can define Fan 3 onwards. Not tried it but it would look something like this:
        M950 F3 C"exp.heater3" Q500 ; RGB Red
        M950 F4 C"exp.heater4" Q500 ; RGB Green
        M950 F5 C"exp.heater5" Q500 ; RGB Blue
        M950 F6 C"exp.heater6" Q500 ; RGB White
        You would probably have to play with the Q (frequency) parameter. you can then control the LEDs with fan sliders in DWC or with M106.
        I'm mid build of a new printer and might actually try this myself
        BLV MGN Cube w/Hemera, K8200, Sunlu S8
        Beersonundefined 1 Reply Last reply Reply Quote 0
        • Beersonundefined
          Beerson @littlehobbyshop
          Thank you for the answer this is exactly what I did but it didnt work...
          I also implied the M307 to deactivate the heaters like it is described.
          If it would have worked would it still be possible to control it via M42?
          • Danalundefined
            Danal
            @Beerson said in LED control like Fans:
            No. You would need to vary fan speeds, by web or Gcode.
            The fans appeared in the web interface, but moving the sliders did not make the LEDs light? Or something else?
            • Beersonundefined
              Beerson @Danal
              so it seems the M950 didnt work because i can still control them via M42
              exactly the sliders did show up but they coulen not control the LEDs
                Which firmware version are you using? M950 only works in RRF3.
                • Beersonundefined
                  Beerson @dc42
                  @dc42 RRF3
                    Send M950 F3 with no additional parameters, to see whether the M950 command worked. Same for F4, F5, F6.
                    • Beersonundefined
                      Beerson @dc42
                      M950 F4
                      Warning: M950 command is not supported
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 16 2020 14:21:00 GMT+0100 (Mitteleuropäische Normalzeit)
                      • Beersonundefined
                        Beerson
                        Aaaaah!! Thank you very much, now it works with RRF3!
                        Thanks for the support!!
