    DuetWiFiFirmware minor release 1.15c
    Firmware installation
    11
    79
    12.2k
    • guywinslowundefined
      guywinslow
      No loose pulleys. Same hardware i was ruining with the Old Duet Controller. have tried to post pictures and movies before at your request. Only to have them blocked. Sorry. Hears my homeall.g file:
      ; Mendel home all file for use with dc42 Duet firmware
      ; Adjust the bed upper and lower limits in config.g (M208 commands) to get the correct homing positions
      G91 ; Set to Relative Positioning
      G1 Z4 F200 ; move hot end up by 5mm
      G1 X240 Y240 F3000 S1 ; Home and set x and y axes
      G92 X220.00 Y212.00 ; Initial homing done, now set fine Adjustments
      G1 X-5 Y-5 F200 ; Back off end stops by 5mm
      G1 X240 Y240 S1 ; Re-home X and Y at slower feed rate
      G92 X220.00 Y212.00 ; Set top level Absolute Coordinates
      ; Adjust the XY coordinates in the following to place the IR sensor over a suitable spot
      ; If you are using a dc42 IR sensor then you can change the coordinates to be near the centre of the bed
      G90 ; Set to Absolute Positioning
      G1 X100 Y100 F6000
      G30
        My only comment on your homing files is that we don't normally use G92 in them any more. Instead we use M208 commands in config.g to tell the firmware what the bed limits are, which are also the positions assumed when endstop switches are triggered.
        Please post your config.g file.
          guywinslow
          Ok, So the Coordinate System Calibration and the Limits need to be the same. Will this affect the Extruder and Y drive Extra movement i am seeing?
          I have run test to see if it actually extrudes 100mm and the y drive actually moves 100mm when i send the G1 Command and that works fine. its just the articulated commands in a print. Almost like a timing error. Any ways the ramblings of and old man.
          Config.g:
          ; Configuration file for RepRap Ormerod
          ; RepRapPro Ltd
          M111 S0 ; Debug on
          M550 PTricolour Mendel WIFI
          M551 Pgdww1620
          M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xEA ; Set the MAC address
          M552 S1 ; Enable WiFi
          M555 P2 ; Set output to look like Marlin
          M906 X800 Y1000 Z800 E800:800:800:800:800 ; Motor currents (mA)
          M305 P0 R4700 T10000 B3988 ; set bed thermistor parameters
          M307 H0 A128.4 C424.4 D2.4 B0
          M307 H1 A762.7 C99.7 D5.5 B0
          M574 X S1 ; Set endstop configuration
          M574 Y2 S0 ; Set endstop configuration
          M574 Z S1 ; Set endstop configuration
          M569 P0 S0 ; Set X Axis Direction
          M569 P1 S1 ; Set Y Axis Direction
          M569 P2 S0 ; Set Z Axis Direction
          M569 P3 S0 ; Set E0 Axis Direction
          M569 P4 S0 ; Set E1 Axis Direction
          M558 P1 X1 Y0 Z1 ; Set Z probe type
          G21 ; Work in mm
          M92 X100.25 Y100.25 Z4001.50 E420.00 ; Set axis steps per unit
          M570 S180 ; Set heater timeout
          M563 P0 D0 H1 ; Create tool 0 = Color 1
          M563 P1 D1 H1 ; Create tool 1 = Color 2
          M563 P2 D2 H1 ; Create tool 2 = Color 3
          M563 P3 D3 H1 ; Create tool 3 = Color 4
          M563 P4 D4 H1 ; Create tool 4 = Temperature for this tool should be Set Low
          G10 P0 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 0 operating and standby temperatures
          G10 P1 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 1 operating and standby temperatures
          G10 P2 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 2 operating and standby temperatures
          G10 P3 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 3 operating and standby temperatures
          G10 P4 X20.0 Y0.0 Z0.0 S0 R0 ; Set tool 4 operating and standby temperatures
          G31 P500 Z0.65 ; Set the probe height and threshold PLA = 0.65, ABS = 0.75
          T4
          M201 X800 Y800 Z15 E1000 ; acceleration tweaks for improved finish
          M203 X15000 Y15000 Z150 E3600 ; speed tweaks for improved finish
          M208 X200 Y200 Z120 ; set axis max travel
          M208 X0.0 Y0.0 Z0.0 S1 ; set axis minimum (adjust to make X=0 the edge of the bed)
          M210 X200 Y200 Y170
          I just realized i still had my M906 command setup for the Old Duet board and expansion board. as there is no expansion board hear and only two extruders i will modify and test. I will also remove the M210 command as well. Looks like its no longer supported
            I see that you have G92 X220.00 Y212.00 in your homing files, and M208 X200 Y200 Z120 in config.g. So your G92 command sets the X and Y position outside the declared printable area. This may account for the jumps you are seeing when homing. I suggest you remove the G92 commands in the homing files and use M208 X220 Y212 Z120 in config.g.
            Also you have M574 X S1 in config.g. I presume it should be M574 X2 S1.
            Is there a reason why your X endstop switch is NC/active high whereas your Y endstop switch is NO/active low, according to your M574 commands?
              guywinslow
              X and Z are the infrared Sensor. I am getting sloppy in my coding. As the X and Y are the infrared Sensor i will comment it out and try
                guywinslow
                Sorry X and Z are the infrared Sensor i will comment the M574 command out
                  guywinslow
                  Ok, had to put X and Z back in:
                  M574 X0 S1 ; Set endstop configuration
                  M574 Z0 S1 ; Set endstop configuration
                    guywinslow
                    Ok, Ran another test print. issue still exists. its like the extruder continues to extrude wall the hot end is moving in word to print the next line. Same thing with my y end stop. the actual hardware stop is close to the point where the switch gets trigger. during the first seek to find the end the controller drives the y past the end just enough such that it hits the hardware before it lock hold the motor. And the next G1 command backs the y table off to do the fine adjustment. Any way and observation
                      It sounds to me that your homing issue is because the endstop switch is not triggering before the physical stop. That would explain the pause. Can you adjust the position of the switch, so that it always triggered before the physical stop?
                      You can post a video to YouTube and link to it from this forum.
                      • deckingmanundefined
                        deckingman
                        @guywinslow
                        Hi. There are a couple of things I don't understand in your config.g. You've set axis directions (M569) for E0 and E1 therefore I'm assuming from that, that you have 2 extruders. Is that correct? Earlier on you've set the motor currents (M906) for 5 extruders but that won't matter if you are only using 2 of them. Later on you've set steps per mm (M92) for X,Y,Z and E, indicating that you only have one extruder. If you have 2 then you would normally have something like E420:420 instead of just E420. I'm not sure how the firmware would react if you only define steps/mm for one extruder but try to use two.
                        Then you have defined 5 tools, each with their own extruder (D0 to D4) but sharing the same heater indicating that in fact you do have 5 extruders, in which case you ought to set steps/mm for all 5. Then for each of the 5 tools, you have an X offset of 20 which means that the nozzles are all 20mm off set in X but the Y and Z offsets are all the same. This would mean that you would have a single nozzle with 5 filament inputs but in that case, you wouldn't need to have an X offset. For tool definitions where there are multiple nozzles, usually one tool would have zero offsets and the others would be offset from that tool.
                        Can you let us know how many extruders and how many hot ends (nozzles) you have and if the hot ends share the same heater? If you have multiple nozzles, what are the physical distances between them?
                          guywinslow
                          Sorry, this was original a copy from the old Duet. Specs:
                          Extrudes: 2
                          Hot ends: 1
                          I indeed fead different Filaments into one hotend (2 feeds). the Tool head offset is do to the fact my x carage was supposed to use two hotends, but i only have on. and its easier to work on in the position its in.
                          hear is a Cleaned up version, i will run a test print using:
                          ; RepRapPro Ltd
                          M111 S0 ; Debug on
                          M551 Pgdww1620
                          M906 X800 Y1000 Z800 E800:800 ; Motor currents (mA)
                          G21 ; Work in mm
                          M92 X100.25 Y100.25 Z4001.50 E420.00:420.00 ; Set axis steps per unit
                          T4
                          M201 X800 Y800 Z15 E1000:1000 ; acceleration tweaks for improved finish
                          M203 X15000 Y15000 Z150 E3600:3600 ; speed tweaks for improved finish
                            guywinslow
                            Just ran test print with the last config i posted. Still have the extra Extrusion when the extruder starts the next shell line. note i am just printing one layer with this test prints, and in this case i am just printing two complete lines around the part. the passing it to look at the print.
                              deckingman
                              I still don't understand you tool definitions. Tool0 (P0) is fine using the first extruder (D0) as is Tool1 (P1) which uses the second extruder (D1) but then you have a third tool (P2) using the third extruder (D2) which doesn't exist. It's the same for your fourth and fifth tools - the extruder doesn't exist. After that, you have a T4 command to select the 5th tool (T0 being he first) but there is physically no 5th extruder associated with it.
                              Assuming that you hot end is capable of mixing, then you need to define the tools accordingly. Something like this
                              M563 P0 D0:1 H1 ; Define tool 0 to use both extruders
                              G10 P0 X20 Y0 ; Set tool 0 axis offsets
                              M568 P0 S1 ; Enable mixing for tool 0
                              M567 P0 E1:0 ; Set mixing ratios for tool 0 to use 100% of the first extruder
                              M563 P1 D0:1 H1 ; Define tool 1 to use both extruders
                              G10 P1 X20 Y0 ; Set tool 1 axis offsets
                              G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                              M568 P1 S1 ; Enable mixing for tool 1
                              M567 P1 E0:1 ; Set mixing ratios for tool 1 to use 100% of the second extruder
                              M563 P2 D0:1 H1 ; Define tool 2
                              G10 P2 X20 Y0 ; Set tool 2 axis offsets
                              G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
                              M568 P2 S1 ; Enable mixing for tool 2
                              M567 P2 E0.5:0.5 ; Set mixing ratios for tool 2 to use 50% of both extruders (or whatever mixing ratio you want)
                              Then repeat the settings for P2 to define the other tools with different mixing ratios.
                                guywinslow
                                My hotend dos not a mixer. its a Standerd Quick-set hotend. dont have any interest in a Mixer.
                                  guywinslow
                                  Forgive me for being cureas, but how is this going to fix my issue with the motors being drive on when they are not supposed to be. I mean this gcode is that same as i used on the Old Duet. So should it not print the same or maybe beater? I can see issues with the Controller not doing well with bad configuration, but that is fixed right?
                                  So fixing the Config.g is a Good place to start. but non of the changes i have made, has solved this issue. Do you guys want me to run a File with a Specific gcode in it? For Debugging?
                                  I mean i can configure it into thinking its got a Mixing hotend, but I don't have a mixing hotend to test it with.
                                    guywinslow
                                    Should i be configuring the Step mode on the Stepper motor drivers? if so what would be the equivalent to the default mode in the Duet?
                                      guywinslow
                                      Sorry old Duet, Example: M909 X3 Y5 Z2 E3
                                        deckingman
                                        Sorry, but I'm just trying to help. I just don't understand how your printer is configured. You said
                                        Quote….......
                                        Extrudes: 2
                                        Hot ends: 1
                                        ...........end of quote.
                                        From that I assumed that it was a mixing hot end. Now you say that it's not. So I'm not sure what you mean. Do you have two extruders but only use them one at a time?
                                        In your config.g you have tools defined to use 5 extruders, 3 of which which don't exist and you have a T4 command which selects one of these tools. I have no idea how the firmware would react to that but it is clearly something that needs correcting.
                                          deckingman
                                          ReRap firmware doesn't use M909. Use M350 instead. I believe the default is 16x microstepping with interpolation.
                                            guywinslow
                                            Correct, i use one extruder at a time. I have a Jig that feeds the filament from 4 extruders into one mounted in the middle of my boden tub
