    Extruder is not working
    Firmware installation
    • Weevilundefined
      Weevil
      I have been struggling with this. My extruder stepper, heater and thermister does not respond. I have confirmed everything is in the right port. The Duet 3 is powered by a Meanwell 24volt 320 watt PS. The extruder is a 24volt configuration. Thanks for any help you can provide. Below is my Gcode, all of it:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
      M550 P"MYTH3D" ; set printer name
      M667 S1 ; select CoreXY mode
      ; Networking
      ;;;M552 P192.168.1.14 S1 ; Use Ethernet with a static IP
      ;;;M553 P255.255.255.0 ; Netmask
      ;;;M554 192.168.1.1 ; Gateway
      M586 P1 S1 ; Enable FTP
      M586 P2 S1 ; Enable Telnet
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards
      M569 P0.4 S0 ; physical drive 0.4 goes backwards
      M584 X0.0 Y0.1 Z0.2 E0.5:0.3:0.4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z4000.00 E420.00:420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 Z500 S0 ; set axis maxima
      M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
      M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
      M143 H0 S280 ; set temperature limit for heater 0 to 280C
      M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
      Danalundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal @Weevil
        @Weevil said in Extruder is not working:
        You've defined Heater 0 and asked the tool to use Heater 1.
        Also, are you selecting tool 0 anywhere? It is OK on a single tool printer to put T0 near the very end of config.g
        Weevilundefined 1 Reply Last reply Reply Quote 0
        • Weevilundefined
          Weevil @Danal
          @Danal Thanks, I have made some changes but the extruder heater is still not responding. PanelDue shows the temp for the extruder at -273.1. I try to set it but it just jumps back. The Web interface shows Heater as undefined under Tools. This is the new code:
          M950 H0 C"out1" T0
          M143 H0 S280
          M307 H0 B0 S1.00
          • Danalundefined
            Danal
            -273.1 is the "magic number" that means a temperature sensor is completely unplugged.
            So wherever you have that thermistor plugged in, it is not plugged into: M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
            or there is a broken wire, or bad crimp, or etc.
            You said this is Duet 3 hardware, correct?
            Temp0 would be here, and is not polarized:
            • Danalundefined
              Danal
              Also, what you showed as a change does not resolve the heater mismatch.
              You must do one of two things (not both):
              M950 must have H1
              -OR-
              M563 must have H0
              • Weevilundefined
                Weevil @Danal
                @Danal That did the trick. Thanks!
