    Duet Web Control Unresponsive
    Duet Web Control
    • Gamefanatic3Dundefined
      Gamefanatic3D
      I've been having problems with the Duet Web Control since upgrading from 2.04 to 2.05.1 not responding. It seems to be okay until I perform a print. After I have trouble getting anything to respond unless I refresh the web page/session. I've been primarily using Chrome to access the site.
      When using /reprap.htm I have no problems, so I believe it may just be a problem with the HTML.
      When the problem occurs I have these issues:
      After a print I cannot upload another, I receive an error and cannot upload.
      Click on the Console, I cannot get a response from G-Code. The "Send" button will change to the twirling circle and never come back.
      When attempting to change the temps on heaters I can typically get my first command to respond, but subsequent actions do not occur. If attempting to change temps there will the stretchy action bars showing something is happening, but never stop.
      Duet Web Control 2.0.7
      Board: Duet WiFi 1.02 or later + DueX5
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
      Duet WiFi Server Version: 1.23
      Any suggestions / known issues?
        droftarts administrators @Gamefanatic3D
        @Gamefanatic3D When it happens next time, can you connect via USB, open a serial console (eg YAT) and send M122? This should report what's going on. Post the M122 output into your reply.
          Gamefanatic3D
          After a print, I made another print and attempted to upload from a Chrome browser. The upload button shows "UPOLOADING" with the circle spinning. Waiting long enough I hear the printer starting in the background...
          I had the reprap interface opened in Internet Explorer prior so I performed the M122 and got this output:
          ‎3‎:‎56‎:‎57‎ ‎PM
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-9T6BU-FG3S8-6J1F8-3SJ6S-1BL7H
          Used output buffers: 3 of 24 (22 max)
          Static ram: 25712
          Dynamic ram: 94472 of which 0 recycled
          Exception stack ram used: 544
          Never used ram: 10344
          Tasks: NETWORK(ready,628) HEAT(blocked,1176) DUEX(suspended,160) MAIN(running,1664) IDLE(ready,160)
          Owned mutexes:
          Last reset 02:50:34 ago, cause: software
          Last software reset at 2020-02-22 13:06, reason: User, spinning module GCodes, available RAM 10280 bytes (slot 1)
          Error status: 0
          Free file entries: 9
          SD card longest block write time: 17.5ms, max retries 0
          MCU temperature: min 40.4, current 40.6, max 44.5
          Supply voltage: min 12.2, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/1023
          Driver 1: standstill, SG min/max 0/487
          Driver 2: standstill, SG min/max 0/129
          Driver 3: standstill, SG min/max 0/72
          Driver 4: standstill, SG min/max 0/113
          Driver 5: standstill, SG min/max not available
          Driver 6: standstill, SG min/max not available
          Driver 7: standstill, SG min/max not available
          Driver 8: standstill, SG min/max not available
          Driver 9: standstill, SG min/max not available
          Date/time: 2020-02-22 15:56:56
          Slowest loop: 225.21ms; fastest: 0.08ms
          Hiccups: 0, FreeDm: 160, MinFreeDm: 121, MaxWait: 17ms
          === DDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
          Heater 0 is on, I-accum = 0.2
          Heater 1 is on, I-accum = 0.6
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is doing "M190 S70.00" in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 200.33ms; fastest: 0.08ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is running
          Failed messages: pending 0, notready 0, noresp 1
          WiFi firmware version 1.23
          WiFi MAC address cc:50:e3:14:e3:17
          WiFi Vcc 3.33, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 25144
          WiFi IP address 192.168.0.108
          WiFi signal strength -47dBm, reconnections 0, sleep mode modem
          === Filament sensors ===
          Extruder 0: pos 188.09, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
          Extruder 1 sensor: ok
          Refreshing the Chrome browser returns control for a while longer.
            Gamefanatic3D
            I just went ahead and updated to 3.0 (2020-01-03b3) and everything is working so far. Probably just a bug or bad update, because it was working before and after the 2.05.1 update.
