    Change request to fans[] value format for LED strip
    Firmware wishlist
    • appjawsundefined
      appjaws
      I want to increase or decrease the value of the fan output for my LED strip by a small amount to enable smooth transitions.
      fans[].requestedValue has 2 decimal places but fans[].actualValue only has 1 decimal place
      Red LED Requested value = 0.14
      Red LED Actual value = 0.1
      Green LED Requested value = 0.08
      Green LED Actual value = 0.1
      Blue LED Requested value = 0.44
      Blue LED Actual value = 0.4
      @dc42 Is it possible to provide 2 decimal places please
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        Yes I can change that. When you use fans[n].actualValue in an expression, you will get an accurate value. It's only the display format that is truncated to 1dp. So you should already be able to use small increments such as 0.05 or 0.01 in your script.
        • appjawsundefined
          appjaws
          Thanks @dc42 for all your help, it now works great.
          Will be even better when we can use variables.
          What would be a good source to learn the syntax of the commands used for conditional gcodes?
          Simplify3D 5.1.2
