    Upgrading RR3 via DWC 2.0.7 to a later version of RR3 error
    Firmware installation
    • Spannersundefined
      Spanners
      Every time I upgrade RR3 from a previous version of RR3 via DWC 2.0.7 (system\upload system files) I get the following error messages in the console although the upgrade is actually successful...
      28/02/2020, 09:26:17 Error
      Operation has been cancelled
      28/02/2020, 09:26:17 M997 S0
      running the M115 command after the upgrade via the console proves that the upgrade was a success but I don't understand what is causing the errors?
      28/02/2020, 09:34:43 M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.01-RC2 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-02-18b1
        When do you get those messages: is it immediately after you have accepted the invitation from DWC to install the new firmware?
        • Spannersundefined
          Spanners
          @dc42 said in Upgrading RR3 via DWC 2.0.7 to a later version of RR3 error:
          I accept the invitation to upgrade then it goes through the upgrade process and only outputs the error messages in the console as it completes the process.
            dc42 administrators @Spanners
            @Spanners said in Upgrading RR3 via DWC 2.0.7 to a later version of RR3 error:
            Are you running with an attached single board computer, or in standalone mode? If with SBC, what version of Duet Software Framework are you using?
            • Spannersundefined
              Spanners
              I'm communicating with the Duet 2 Maestro over an Ethernet link connected to my router, I use a wireless laptop to connect to the DWC so stand alone I think is the answer your looking for.
              I don't know what a single board computer is unless you mean the likes of a Raspberry pi which is not what I am using?
                Sorry, silly question.
                Those messages are coming from Duet Web Control, but I don't know why. One for @chrishamm.
