    Tempeture graph
    Firmware installation
    • chainbreaker2012undefined
      chainbreaker2012
      Installed a duet 2 wifi about a week ago and upgraded the firmware to 2.05 but not the tempeture graph doesnt work for the hotend or the bed. The tempeture readouts are fine and it prints just like it should. The graph worked before the update as well. Any ideas or did I forget to do something? I downloaded the combination file that had everything in it if that helps.
      Board: Duet WiFi 1.02 or later
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05 (2019-12-13b1)
      Duet WiFi Server Version: 1.23
        What version of DWC is installed?
        Do you mean there are no temp lines on the graph?
          chainbreaker2012
          Correct no tempeture lines on the graph. I think I may have got it though I hit the revert back to DWC button and it went back to the original looking screen and got the graph back working again, then reloaded the firmware and it seems to be working now although I did try this before I posted. Not sure what happened the other times but hopefully it stays working now. Either way I appreciate your response. Quick question I want to go to the 3.0 firmware Is there really allot of stuff to change in the config files for it? It seems almost overwelming looking over the changes and all that.
            RRF3 can be a little confusing if you're used to RRF2, but if you use the web configurator and have a basic setup, it should be able to give you a good starting point.
            Update your DWC to 2.0.7 if you haven't already.
              chainbreaker2012
              ok I will give it a try, Thank you!
                There's also nothing wrong with sticking with 2.05 for the time being unless there's a specific feature in RRF3 you need. Development is still heavily underway, so there will likely be some bugs and missing features for a while.
