    Z sensor works but the mators do not align the table
    Firmware installation
    • Vladimirundefined
      Vladimir
      Good afternoon.
      I can 't deal with the bed automatic leveling. The probe operates, but the motors do not align the bed. What am I doing wrong?
      In advance, thank you for your answerhomeall.g config.g bed.g
        Phaedrux Moderator @Vladimir
        @Vladimir said in Z sensor works but the mators do not align the table:
        What do they do? Do they make it worse, or do they just take a few runs to get it aligned?
        • Vladimirundefined
          Vladimir
          This post is deleted!
          • Vladimirundefined
            Vladimir
            When starting auto bed leveling from DWC, the probe (NPN output normally-open inductive or capacitive sensor) checks the bed tilt at two points, but does not automatically align it. If I understood correctly, then the engines should do this automatically, but they are silent ... (. P.S. table I intentionally set crookedly with a height difference of 0.5-1cm.
            • Vladimirundefined
              Vladimir
              Good afternoon. Is it clear enough that I set out my question?
                In your config.g your G31 command is missing the XYZ offsets.
                G31 X0 Y0 Z0
                You'll need those for accurate probing results.
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                M584 X2 Y0:1 Z5:6 E3
                Are you sure these are the correct driver assignments? You don't mention what board you're using, or what firmware version.
                Your homeall looks to have some errors. First you're not using the z probe for homing.
                G1 H2 Z10 F1800         ; опустить стол на __мм
                G1 H1 X-1000 Y-1000 F2400      ; X - домой
                G1 H2 X20 F1800
                ;G1 H1 Y-1000 F2400
                G1 H1 Z-1000 F1800        ; move Z down stopping at the endstop
                G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                G92 X0
                Are you sure you want to force the position of the X axis to be 0 at the end of homeall?
